Sony RX0 ii at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony RX CyberShots and CX Series Camcorders
Pro quality results from Sony consumer grade equipment.
Old April 17th, 2019, 04:18 PM   #1
Sony RX0 ii
4K video internal, with stabilization. Handheld example, shot in slog2:
Mark Rosenzweig is offline   Reply With Quote
Old April 18th, 2019, 12:57 AM   #2
Re: Sony RX0 ii
Says "1080p" on my iMac "5K' albeit I'm watching via "Safari".
Ron
Ronald Jackson is offline   Reply With Quote
Old April 22nd, 2019, 07:24 AM   #3
Re: Sony RX0 ii
Ron
Says 4K on my laptop, my editing computer, my office computer. Certainly not a camera issue!
Old April 22nd, 2019, 07:26 AM   #4
Audio Test Video of Live Music: Internal Mics
Old April 22nd, 2019, 10:38 PM   #5
Re: Sony RX0 ii
Any recording time limit in 4K, or overheating issues (since it's such a small form factor)? Looks pretty impressive for the size and price!
Old April 23rd, 2019, 08:11 PM   #6
Re: Sony RX0 ii
No recording time limit. Zero. One reviewer showed 48 minutes of straight recording of 4K until battery exhausted. Not hot enough here to really assess overheating in hot ambient temperatures.
Old May 9th, 2019, 12:54 PM   #7
Comparison of 4K Image Quality with and without Stabilization
The RX0 ii employs EIS (Electronic Image Stabilization), which crops - how big is the crop? And does use of EIS lower resolution?
You can see here: the first image in each scene is with stabilization turned on, the next is when it is turned off. The transition will be obvious, since you will see the reduction in the crop when stabilization is turned off.
These shots were made with the camera on a tripod. Shot in Slog2 and graded.
Old May 15th, 2019, 05:09 AM   #8
Time-Lapse - in the Rain
None of the latest RX100 and RX10 can do time-lapse. And they cannot stay out in the pouring rain for 24 minutes.
Old June 1st, 2019, 05:15 PM   #9
Re: Sony RX0 ii
Old June 9th, 2019, 08:23 PM   #10
Another Audio Test - Internal Mics
Slog2, graded. On Zhiyun-tech Smooth Q gimbal.
Old June 24th, 2019, 05:34 PM   #11
Time-Lapse, Slow Motion, Anamorphic Examples
Old July 3rd, 2019, 09:34 AM   #12
Improved True 4K Anamorphic Video with Moondog Adapter
Now using the Moondog faceplate, which eliminates vignetting:
Also, ND filter used.
Old July 6th, 2019, 07:24 PM   #13
More anamorphic videos
One anamorphic lens flare!
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony RX CyberShots and CX Series Camcorders
