Difference between PDX10 and TRV 950?
I'm sure this has been asked countless times before, but what are the major differences between the two cameras?
Thanks for your time Trevor |
Major differences:
XLR audio inputs module on PDX10 14-bit video processing in PDX10 Included large hood with PDX10 DVCAM recording with PDX10 Better 16:9 mode PDX10 Built in flash on '950 Bluetooth and IP on '950 (I think) |
Wow, really? The 950 doesn't have the 14-bit video processing? That seems like a significant difference.
Some other PDX-10 features for your list:
BW hi res viewfinder settable timecode and user bits choice of 0 or 7.5 IRE setup separate volume control of each stereo channel black finish |
Ha! That is not real setup. It DIGITALLY records with a fake added luma. Very weird. |
950 has bluetooth (nice feature, at least to me)
Does that allow you live stream an image to a web server using a bluetooth equipped cell phone? Even if it's a still image, great for mobile webcasting of events as they happen... |
Hi,
The 950 has 14-bit DXP. Most Sony Megapixels camcorder has this chip. |
> camcorder has this chip. Not that I don't beleive you but where did you get that info from? I searched and searched and found nothing. |
Ignacio,
Go to the Sony Website. Look up the TRV-950. Click on specs. Then, download the .pdf file with the specs. It is noted in the .pdf file that the image processing is 14Bit. |
> download the .pdf file with the specs. Cool. Thanks. Stupidly I never thought of checking the TRV-950 manual! |
Ignacio,
I think the info is pretty obscure. Plus, at least you did not receive your camcorder and then think the headphones were broken for a week because the volume output to them was turned all the way down....um...like some others on this forum....;-) |
