Video light recommendations
My project of filming a track meet went into the dusk hours and I found myself without light.
Can someone please advise me on a good video light for my PDX10? Thanks |
Be aware that a light is only going to work at very close range. You'll get night interviews out of it, but nothing really in terms of shooting night action.
Well, that makes a big difference! I'll address my shooting times so I won't have to purchasea flood lights.
Thanks for the info. |
lights
Yeah, I don't think camera lights would help at a track meet, unless you are a fast runner and plan on following the athletes around the track.. :-)
You can experiment with setting the shutter speed to 1/30 sec. You'll get a small loss of resolution and a little more motion blur, but your video will be brighter, of course. -Jeff |
It's really good to use the Sony HVL-20DW2 simply because it'll run both 10 watt lamps for well over an hour on a 960 battery. It locks down onto any conventional shoe and has no dangling wires or different battery packs to worry about. Small, compact, light, but not cheap.
I use it with a Lumiquest Mini Soft-box diffuser. It robs me of a good stop of light, but the effect is wonderful - soft, blurry shadowed even lighting that means I can use my powerful 0.5x converter with ease. Also the diffuser means no-one squints into the light. Perfect for my wedding shoots. tom. |
I've never seen the Lumiquest diffuser--sounds like a winner.
I have a couple cheap Bescor VL-30 lights (20 watts) and I found a cheap way to soften and further diffuse the light (I put a couple layers of baking paper over the light). It brings it down a stop or more, depending on how many layers you use, and improves the built in diffusing of the VL-30. Plus the baking paper can obviously handle the heat of the light. Probably not as good as your setup, but it gets the job done on the rare occassion I need a video light. |
Thanks for the advice about the Sony HVL-20DW2. I checked B&H and the price was $79. I can live with that. However, they are out of stock. This must be either a popular light or an old one. Either way, I'll obtain it.
I was thinking that I can just focus on getting footage at the pit (long and triple jumps) and not as the runner goes down the runway. I don't plan to run behind these folks. Besides I wouldn't want to embarrass them by keeping up (smile). The area is 30-35 feet and I'll be up close so it should work out. Thanks |
