Microphone Input
Does anyone happen to know if the mic input or jack is a stereo jack requiring ring, tip,
sleeve jack or if it is a monoaural jack needing just tip and sleeve? And has anyone used the Samson Mixpad 4 and if so, what did you come out of on the mixer to get into the camera? Thanks much. Jay Roper |
Stereo. I've forgotten which channel is assigned to the tip and ring. Sleeve is the ground. You can select microphone or line level input.
I have not used the mixpad but adapters can be had at Radio Shack for adapting it to the camera. |
Tip is left channel on stereo jacks. Some camcorders (Sony and maybe others) have a DC (2.5V) component on the inputs in order to automatically switch between mono and stereo mics. If you want stereo, avoid a DC conduction path between the tip and ground.
Thanks guys - I really appreciate the input.
Jay Roper |
