camera troubleshooting
Hi,
Hope this is the right place to post this. Need your help with troubleshooting camera problem. I have a Sony Vx1000 and just replaced the viewfinder ribbon cable and now the viewfinder works but now everything is red (was color and normal before) do you think it's the cable or maybe I screwed something up while fixing it and exploring (damm my curious nature). Wil |
I've moved your thread to the Sony VX/PD forum.
It sounds like you either connected it wrong, not secure enough or you broke something. As has been said time and time again on this forum which you just experienced, most camera internals are NOT user servicable! Even with good electronics knowledge it is easy to break something inside a camera if you don't know how it is put together (and how it should come apart etc.) This probably calls for a decent repait job at an expert or Sony themselves. Why did you do this in the first place? If nothing was broken you may have created the need for an expensive repair. |
Actually the veiwfinder was totally broken.
I did take it in to get serviced but the guy I brought the camera to (the only place in the city that did Sony products) said that the part I needed was discontinued and the replacement part that he had didn't fit. So I thought I was SOL. Then I found the part on ebay and also found a step by step direction guide to change it, and it wasn't that hard. I have since opened it up again and made sure the connections were secure. Do you think that the cable is no good? Would it be worth looking for another cable or do you think it's something else? But on the plus side, I can see some images in viewfinder and see the menu, as opposed to nothing like before. Any help would be great. Wil |
