Really need some advice about Mack warranty trouble
Sent in a 2100 with a couple bad pixels to Mack.
Cam is outside the 90 day sales period but inside the one year period. Sent along a diagram of where the pixels are located and at what shutter speed they appear. Mack sent the cam back saying two techs had looked at it on the LCD and on a monitor and could see no problem. The problem is obvious at 1/30th and below on the LCD and on a monitor when aimed at a dark area! The pixels are recorded onto tape as white spots. You can see them on the LCD. You can see them when plugged into a TV through RCA, when the cam is pointed into a darker corner of the room. You can see them on the recorded tape when pulled into an NLE. And they're always in the same place. I could post a picture and everyone could see it. What do I do now? This is a major bummer, and first shows itself to a minor degree at 1/60th, getting worse as the shutter speed gets lower. P.S. If there's some way to upload pictures here, taken from imported stills, I could do so and it would be obvious. |
Insist on speaking with a manager about the problem and send the package addressed to them.
Make the print, document the conditions and send them with the camera. Don't accept their position. Get very pushy if necessary. |
