Need Adapter Plans
Well, I tried searching the DV Mag website. Very cool, but I could not find the article authored by Mr. Rose that I need. What I am looking for is the plans for an XLR adapter that has the capaisator[sp] that will block the dc voltage coming out of the vx.
Thanks for the help. This is the best site with the best people on the Web! |
Took a few seconds to type capacitor into the search box and viola. Had you posted a question jay would have responded quickly'
The proper configuration is XLR stereo miniplug 1 ---- sleeve 2 --*- tip AND ring 3 ---- sleeve (or tie to pin 1 at the XLR) * -- If the camera's power is causing distortion in the mic, put a 100 uf / 10 volt capacitor here, + side to miniplug. http://www.dv.com/forums/showReplies.jhtml?sid=1&fid=3&tid=57500005 Courtesy of Jay Rose at DV.com As I have written in an other thread, it is cheaper to buy the cable and modify it with a capacitor. Hosatech cables are under $10 at B&H. You will have a hard time finding a 90 degree molded male stereo jack. You use a straight jack and your begging for trouble. http://www.hosatech.com/audio_cables_index_3.html look for the XVM-101 http://www.bhphotovideo.com/bh2.sph/FrameWork.class?FNC=ProductActivator__Aproductlist_html___158476___HOSMMRAXF1___REG___CatID=0___SID= F4CC1D73CF0 |
Thanks Bryan! You guys always come through! I tried searching under "XLR" amd "adapter. Dohh! I
Thanks Again! |
blocking capacitor
As Bryan Beasleigh wrote in his post:
* -- If the camera's power is causing distortion in the mic, put a 100 uf / 10 volt capacitor here, + side to miniplug. From my experience capacitor 100uF is too high for audio signal. Best capacitance should be betwen 100nF to 1uF. After I checked service manual for VX2000, microphone circuit is blocked wit 100nF non polarized capacitor. |
so, what is the best capacitor to use then for the vx-2000?
someone had their child draw a circuit diagram of this; http://www.audiotheater.com/miniphantom.html this is correct, correct?
Lower value of capacitor will cut-off low frequencies for speech is usualy value 33nF to 47 nF. For wider range of frequencies ( like music frequencies, use 10MF to 47 MF.
100MF and up will not hurt the system, just is becoming to bulky to fit inside any connector. In my aplication ( preamplifier for microphone) used with VX2000 I used 47MF polarized capacitor 16V tantalum. |
"someone had their child draw a circuit diagram of this"
Looks like something i might draw. Not pretty but at least the artist understands the subject matter. |
