What is the quality difference between miniDV and DVCam
Can anyone tell me shortly if a differnce can be seen between a footage made in DV and DVCam?
I use already a DV Camera but I have to look for another one. The spec of the PD100 would fit my requirements and is cheaper than the VX2000. Are there big differences between the VX2000 and the PD100 except from the recording format. |
I don't have much experience with the DVCam format, nor do I know the specific technical specifications of each, but I can tell you that miniDV, DVCam and DVC Pro all use 4:1:1 processing, with a data rate of 25Mbytes per second. What that means, essentially, is that the only difference you'll see depends on the camera you use. Variables such as the number and size of the imaging chips, the quality of the lens, and signal processing are all going to affect the quality of the picture. Simply put, a $10,000 "pro" camera is going to look better than a $500 palmcorder. You get what you pay for (to a certain extent). I hope this helps.
Bill S. |
Thanks Bill,
The DVCam records the video signal with a faster speed than the DVmini. But as you said they all process with the same rate. I ordered a PD100 now as Sony Europe had some B-ware of it and the price had been cut off by 50% . Which comes cheaper now than the VX2000. Klaus |
Quickly, the difference is DV has a track pitch of 10 micron, DVCAM is 15 micron and DVCPro is 18 micron. DV has unlocked audio, DVCAM has locked audio and DVCPro has an analog audio reference track. What this means is that only DVCAM will sync the audio exactly to every frame in the video while DV (and mini DV) will allow the audio to slip out of sync, especially on long takes. The plus side is that the slip is not that bad (usually only a few frames per min).
DVCAM and DVCPro write SMPTE time code not DVTC (consumer). And although you can use DV tape to record DVCAM, the DVCAM tape is made with MUCH higher tolerances and quality materials and has the optional micro chip for added features and labeling. The actual quality difference is still limited to 500 lines in any format but the DVCAM (and DVCPro) formats are built for professional use (and abuse). |
DVCAM, because of the better pitch and speed, supposedly has fewer dropouts than DV. I haven't experienced any dropouts with DV, so this statement is superfluous, IMHO.
