Lens Size??? at DVinfo.net
Old October 21st, 2007, 09:23 PM   #1
Lens Size???
I have asked this question is several threads and haven gotten answer yet.
Is it 72..82???
Just bought the Letus Extreme and need to know if I need a step up/down ring.
TIA!
DBoZ
Daniel Boswell is offline   Reply With Quote
Old October 21st, 2007, 10:02 PM   #2
Is it designed to work with 1/2" chips?
Doesn't this make a difference to the design? Just wondering out loud.
Jus.
Justin Benn is offline   Reply With Quote
Old October 21st, 2007, 10:09 PM   #3
Jus.
Not sure what you mean. The Letus design?
DBoZ
Old October 21st, 2007, 10:25 PM   #4
77mm. pitch 0.75 mm (on lens).
Vaughan Wood is offline   Reply With Quote
Old October 21st, 2007, 10:47 PM   #5
1/3" versus 1/2"
I meant, isn't there a reason why folks like P+S make different devices for your camera depending on chip size or am I missing something? Surely an imaging device designed to project light to a 1/3" capture chip will not natively work as well with a chip which is significantly bigger in area? Ie. you'd not be using the full extent of the larger chip, right?
Old October 21st, 2007, 11:01 PM   #6
Images: 3
The Letus website has no information about field of coverage, but I guess is designed for 1/3 inch sensors and smaller. You should ask them whether it will cover a 0.5" sensor with vignetting.
EDIT: I think there isn't a problem. The camera lens is focused at infinity using a supplementary lens to video an image on ground glass, so provided the ground glass is uniformly bright the primary lens takes care of coverage.
Old October 21st, 2007, 11:27 PM   #7
Disjecta
Daniel,
Where did you buy the Extreme? If it was from www.letusdirect.com then you were given a choice of 72mm or 82mm thread size. If you didn't choose one, it defaults to 72mm.
Try my Digital Therapy: http://www.pinelakefilms.com/digital_therapy.html
Films on ExposureRoom: http://exposureroom.com/members/disjecta.aspx/videos/
Steven Dempsey is offline   Reply With Quote
Old October 21st, 2007, 11:36 PM   #8
Originally Posted by Steven Dempsey View Post
Daniel,
Yeah..I bought it from their website and just chose 72mm not knowing what the EX was at the time. Adapter rings arent a big deal but i'd rather not use one if I don't have to.
DBoZ
Old October 22nd, 2007, 06:15 AM   #9
So it better to buy the Letus with 72mm or 82mm thread size?
Is it better to "step up" or "step down"?
Or maybe it doesn't matter...
David Koo is offline   Reply With Quote
Old October 22nd, 2007, 08:21 AM   #10
Love to try it.
I guess that makes sense. Guess I'll wait for some reports about what actually works in the field.
