Chromatic aberration at DVinfo.net
Old April 18th, 2008, 07:35 AM   #1
Does anyone know how to get rid of it? Im using an iscorama 54 anamorphic adapter on an EX-1 and noticing a degree of colour fringing sometimes that just doesn't happen on the EX-1s amazing lens. Just wondered if anyone knew of a program to get rid of this?
Mark David Williams is offline   Reply With Quote
Old April 18th, 2008, 08:16 AM   #2
Iscorama 54 huh? So you're shooting 2.66:1 movies. Great! The punch of that is probably worth having some fringing on board.
Old April 18th, 2008, 08:49 AM   #3
Agree Tom!
Old April 18th, 2008, 10:03 AM   #4
Mark,
It depends on the type of aberration. You might be able to run the footage through after effects and scale the RGB channels differently if it's a simple type of fringing. Other things you can do is to key the fringe colours and desaturate them, sometimes this can work, it really depends on the type of footage.
I'd love to see a frame. What's the resolution like through that adaptor?
cheers
paul
Paul Curtis is offline   Reply With Quote
Old April 18th, 2008, 11:16 AM   #5
Hi Paul
This is without the anamorph
http://www.freewebs.com/markwilliams/without.png
And this is with
http://www.freewebs.com/markwilliams/Anamorph.png
Old April 18th, 2008, 11:21 AM   #6
Oh dear - I see what you mean. Almost better to mask down the original frame rather than have to accept wooshy edges like that.
Old April 18th, 2008, 11:40 AM   #7
I was about to say something similar. i thought the lens would give you a much wider fov. In this case you'd get better results cropping the original down as Tom says.
Is the adaptor meant for 4:3 cameras perhaps?
Having said that you could squeeze the channels horizontally (try expanding the red a little bit widthwise, 100.25%), i think it would clear it up a bit. Or run it through a photographic (RAW converter) style defringer.
cheers
paul
Old April 18th, 2008, 11:57 AM   #8
Images: 10
VirtualDub has a free CA correction filter. Do a search.
Old April 18th, 2008, 12:01 PM   #9
Bill I was just thinking about you! I was using your picture profile when I took it. This is with Picture profiles off
http://www.freewebs.com/markwilliams...20pp%20off.png
Old April 18th, 2008, 01:30 PM   #10
Err, having looked at the pictures; donīt really know which way to take this. Better without?
Mika Tertsunen is offline   Reply With Quote
Old April 18th, 2008, 01:42 PM   #11
Mika I would say no difference with PP on or off. I just thought people might like to see nd judge for themselvves. Bill I've found the plugin and downloaded virtual dub. Imported the picture and added the filter. However I cant see the effect in the preview screen? When I do get a preview screen its zoomed in so much cant see a lot?
Old April 18th, 2008, 01:57 PM   #12
I would guess though whatever I do Im not going to get rid of this! Im surprised virtual dub has a tool like this and after effects doesn't.
Old April 18th, 2008, 02:31 PM   #13
I wonder if I moved the iscorama forward a bit? I'll try that tommorow.
Old April 18th, 2008, 03:23 PM   #14
I guess you could get away with it quite simply by forgetting about the anamorphic adaptor, having framing guidelines in your monitor/viewfinder and cropping afterwards. I donīt know if itīs possible to define a box cursor to the ex, hardly so.
Old April 19th, 2008, 07:08 AM   #15
Images: 10
The PP settings won't be the cause of CA.(doncha just love acronyms?)
But, my question to you is what aperture settings did you use on the shot with and without CA. CA, in hi quality optics, is made worse by long zooms and apertures too far from the sweet spot. If you were shooting down around f/8 or less, this would be my guess. Also, how does the adapter mount to the cam lens? If it's tilted, even slightly, relative to the lens axis, you could induce CA.
Bill Ravens is offline   Reply
