Convert 720p60 to 720p30 with frame dropping? at DVinfo.net
Old February 22nd, 2009, 05:01 PM   #1
Hi,
What software do you use to convert 720p60 (shutter =1/125) to 720p30 ? I was hoping that Sony Vegas 8c would do the job, but 720p30 video is blurrier, as if the frames were averaged instead of dropped. I've rendered my Sony Project to an MXF file.
Thanks for any help.
Gints Klimanis is offline   Reply With Quote
Old February 22nd, 2009, 05:15 PM   #2
Images: 10
If your source is 60p, then converting to 30p will, typically, just drop one field from each frame to give you 30p. In effect, you're halving your resolution by dropping one field per frame.
I might suggest setting project properties to interlaced, then exporting to progressive with "blend fields".
Old February 23rd, 2009, 01:57 AM   #3
Hi Bill, The interlace method you suggested didn't produce a difference. Sami answered this question in another thread:
http://www.dvinfo.net/conf/what-happ...egas-8-0c.html
edit: thread link corrected. Sorry, Bill
BTW, Bill, I really liked your Picture Profiles for the EX1. The colors are excellent, and I've always had outdoor trouble with overexposed light skin. Your profiles keep them in range.
Old February 23rd, 2009, 07:05 AM   #4
Images: 10
thanx, Gints.
BTW, your link just sends me back to this thread. But, I am curious what Samy recommended.
edit: ahh, I found it.
Old February 23rd, 2009, 01:42 PM   #5
That would be true if the source material was 60i. However, 60p does not contain any fields - only whole frames. So dropping half of them should not affect the vertical resolution only the temporal resolution.
Ola Christoffersson, Kamrat produktion, Stockholm - Sweden
www.kamrat.tv
Ola Christoffersson is offline   Reply
