Remote for EX3 at DVinfo.net
Old July 16th, 2009, 01:27 AM   #1
Remote for EX3
Are there any simple remotes that plug into the back of the EX3 (not the lens), just for starting/stopping record? Preferably fixed to the panhandle.
Dave Tyrer is offline   Reply With Quote
Old July 16th, 2009, 06:41 AM   #2
There is a wireless remote control that comes with the camera
Ed Kukla is offline   Reply With Quote
Old July 16th, 2009, 08:07 AM   #3
Yes Ed...I did notice :-) but that's not what I had in mind. I want something that fits on the panhandle. I was looking at this but I don't know whether it works on the rear remote connection or only the stock lens connection.
Manfrotto 521EX - RC SONY EX-CLAMP
Old July 17th, 2009, 03:48 AM   #4
What are other people using, when 35mm lenses are fitted ?
Old July 17th, 2009, 11:05 AM   #5
Sony remote control paint box
Not that this in any way attaches to the pan arm, but it will start/stop the camera and plugs into the rear of the camera.
The same paint box that runs the F900 runs the EX cameras-sorry I do not have the model number.
Check the EX website.
Paul Zwicker is offline   Reply With Quote
Old July 17th, 2009, 11:09 AM   #6
Thanks Paul..it really does need to be on the panhandle. I had one of the vendors speaking to Sony today about this...it may be possible they will bring something out in the future.
Old July 17th, 2009, 06:26 PM   #7
This is the very question I asked Phil Bloom when the Letus relay was launched, never got an answer. Phil if you are there, how do you trigger the EX-3 when run and gunning with a relay on the EX-3? or are you restricted to just the button on the camera top plate?
Dan
Old July 17th, 2009, 07:25 PM   #8
Vortex Media
Almost any rear zoom controller you buy for the EX1 (or any camera) will also include a record Start/Stop control, and usually a Return button as well.
Personally, I use the Bebob Zoe with my EX1, but I could'nt say whether it is any better than other brands since I haven't tried the other brands.
Bebob Engineering | ZOE-EX Zoom Controller for Sony | BE-ZOE-EX1
Old July 17th, 2009, 11:55 PM   #9
Doug,
I think you miss the point, when you remove the EX lens and fit a 35mm adapter and relay lens then you are also removing the remote control socket. This leaves the remote socket on the rear of the EX-3 which is non-standard and currently only support a couple of very expensive Sony controllers which are not pan handle types.
There is an adapter from Fujinon Fujinon ACM-21 Lens Mount Adaptor for Sony PMW-EX3 :: HDV, HD Lens Adapters :: Optical Lens Adapters :: Lenses & Optical Lens Adapters :: Equipment Sales :: Abel Cine Tech that might work but it has glass in it, not ideal for a relay lens setup.
Dan
Old July 18th, 2009, 03:47 AM   #10
Originally Posted by Dan Chung View Post
Doug,
Dan
Thanks Dan..finally someone that understands..lol. I think I'll have to get used to operating the button on the top.
Dave
Old July 18th, 2009, 05:30 AM   #11
Vortex Media
Doug,
Oops. You're right. I did miss the point. Sorry for not reading the question closer.
The Sony RM-B150 will do what you want it to do but it may not be worth the expense and it may be a challenge to mount it on the pan handle.
Sony | RMB-150A Hand Held Remote Control | RMB150//A | B&H Photo
On both my EX3 and EX1, I have Assign Button #3 permanently programmed for "Record Start/Stop" because it is in a very convenient location that is easy to find with my left hand without looking. My left hand is usually on the lens anyway, so it's a small motion to slide over and hit the button. Unless I'm shooting hand-held, Assign #3 is actually the only record button I ever use.
Using an Assign button might not be the solution you are looking for, but it's better than using the button on top of the handle.
Old July 18th, 2009, 06:10 AM   #12
Doug that's a great idea thanks...much better than fumbling about trying to get to the button on the handle. My buttons are about to be re-assigned.
