Help in FCP ,Nanoflash and PMW EX3 at DVinfo.net
Old October 29th, 2009, 10:28 AM   #1
I am in trouble. I am away from the city shooting a feature film on PMW EX3 on NanoFlash.All my three cards(SanDisk ExtremeIII) are full. My footage is in QT XDCAM HD 422 100mbps.I have a Mac FCP6.0.1 on location . Files are not opening .I know minimum FCP 6.0.2 is required. Can somebody tell me if I simply copy it in FCP 6.0.1 and later edit it in FCP 6.0.4 the footage is safe?
Ramji Meena is offline   Reply With Quote
Old October 29th, 2009, 11:17 AM   #2
Since these files are just .mov, copying the files to your drive is independent of FCP. Just copy the files and then edit when you are at computer with compatible version of FCP.
Ned Soltz is offline   Reply With Quote
Old October 29th, 2009, 01:59 PM   #3
Thankx
Thank you Ned.I believe there will be no resolution loss .i am copying through firewire800 reader.
Old October 29th, 2009, 03:21 PM   #4
I would copy the files to your Mac then open each in Quicktime. This will let you check each file and also look at Movie Inspector to check the color spacing and bit rate to see if all is well. If you have a external hard drive back them up there so you have two copies.
Paul Cronin
www.paulcroninstudios.com
Old October 29th, 2009, 08:58 PM   #5
my problem is that I am not been able to open the files in QT also.The copied file size is ok but I am not been able to see wether the footage is ok or not.
Old October 29th, 2009, 09:54 PM   #6
Is your system missing the XDCAM codecs?
I don't recall which FCP update added them, maybe someone here remembers.
Sorry, but that's all I can think of at the moment.
[PS: Although it doesn't help you now, your situation is why some of us strongly recommend that people test their workflow *before* their shooting event.]
EX3, Z1U, FX1, D1X / NeXTstation Turbo Color / FCS3
Brooks Graham is offline   Reply With Quote
Old October 30th, 2009, 02:28 AM   #7
post has been removed.
Last edited by Andrew Stone; October 30th, 2009 at 02:30 AM. Reason: post was incorrect
Andrew Stone is offline   Reply
