Audio-settings EX3 at DVinfo.net
Old February 7th, 2010, 07:48 AM   #1
Audio-settings EX3
Hi: The audio-settings for recording-mode on the EX3 are factory-set to -41db. But it seems to me that sound from external mikes doen't come in well. Always sounds a bit "distorted".
What's a better autio-setting in order to get cleaner sound?
Thanx!
Heiner Boeck is offline   Reply With Quote
Old February 7th, 2010, 07:52 AM   #2
If you mic is "hot", try using a bit more aggressive trimming like -35dB (or even -30).
Old February 7th, 2010, 10:42 AM   #3
My mike is a Rode NTG-2
Old February 8th, 2010, 02:54 AM   #4
Thanx!
Make sure you haven't set the input selector to "Line". I had the same problem on a recent location shoot, someone had messed about with the switch - luckily I spotted it whilst monitoring the audio.
Vincent Oliver is offline   Reply
