slo-mo on 320 at DVinfo.net
Old April 7th, 2012, 11:59 AM   #1
slo-mo on 320
trying to do some slo-mo in camera when i go to Rec Function its all blacked out in the menu!! yes i know its something i have turned off or thats not on but can you point me in the right direction,
thanks Ian
Ian Thomas.
Thomas Video Productions
Ian Thomas is offline   Reply With Quote
Old April 7th, 2012, 12:49 PM   #2
Re: slo-mo on 320
Be sure that you are in the 720p mode first, in order to shoot 60fps.
Will not work if you in 1920x1080 mode.
Paul DeBaets is offline   Reply With Quote
Old April 7th, 2012, 02:31 PM   #3
Re: slo-mo on 320
thanks Paul
i tried this but still in the Rec function all the options are blacked out in the menu bit puzzled anybody?
Ian Thomas.
Old April 7th, 2012, 04:36 PM   #4
Re: slo-mo on 320
In the 'Operation' menu ('OP'), go to 'rec function', then choose 'slow & quick'. This should be highlighted if the camera is set to 25p (or 30p in your case). S&Q motion does not work in interlaced mode, only in progressive. It does work, however in both 720 and 1080.
Old April 8th, 2012, 02:35 AM   #5
Re: slo-mo on 320
Hi Luc
I have the camera set to 720p 25p when i go to rec fuction all is blacked out? is there something else iam missing
Ian
Ian Thomas.
Old April 8th, 2012, 03:52 AM   #6
Re: slo-mo on 320
Q & S motion is only supported when using SxS cards. You're not using an SDHC adapter with SDHC cards, by any chance? You can also check if the camera is not set to HQ1440 instead of HD 1920. Q&S do not work in 1440 mode.
Old April 8th, 2012, 05:22 AM   #7
Re: slo-mo on 320
Hi Luc
Yes iam using sxs cards and the camera is set to HD 1920 and i have unpluged nano and still the Rec function menu is blacked out, But i do know that cache record works as i have this assingned to one of my assign swiches which also on the Rec Function menu, Something must be set in the menu that stops it from showing the rec function or the camera is faulty but it has worked before HELP
Ian Thomas.
Old April 8th, 2012, 05:25 AM   #8
Re: slo-mo on 320
Save your camera setup on a SxS card then do a factory reset on the camera. See if that makes the option available.
If so reload the setup file from the SxS card and see if you still have access to it. If not you know it is a setting and not a broken camera.
http://www.LandYachtMedia.com
Old April 8th, 2012, 05:55 AM   #9
Re: slo-mo on 320
Thanks for the help I have sorted it now I canceled all my assign buttons and tried it again and the rec function is now operational so it must be something i had set to a assign switch
Thanks again
Ian
Ian Thomas.
Old April 8th, 2012, 12:07 PM   #10
Re: slo-mo on 320
glad to see the problem got solved. Cheers
Old April 8th, 2012, 12:59 PM   #11
Re: slo-mo on 320
thanks Luc
will have to find which assign switch setting it would'nt work with
Thanks Ian
Ian Thomas.
Old April 8th, 2012, 04:09 PM   #12
Re: slo-mo on 320
Well, it's certainly not the cache function, because I can switch that off and on and the 'slow & quick rec' stays highlighted in both cases.
Luc De Wandel is offline   Reply
