4 copies of an EX1 clip at one go ! at DVinfo.net
Old May 14th, 2012, 03:03 AM   #1
When I copy a clip from the EX1 to an HDD on the PC using Copy/Paste in the Sony Clip Browser I end up with 4 copies of the clip rather than the 1 copy I was expecting. Why is this ? Should I just delete 3 of the 4 copies and forget it ?
Premiere CS5, EX1, 2xFX1,SonyA1,GlideTrack.
Mike Wade is offline   Reply With Quote
Old May 14th, 2012, 06:23 AM   #2
Images: 3
Re: 4 copies of an EX1 clip at one go !
Are you certain that you have 4 identical copies?
Old May 14th, 2012, 06:44 AM   #3
Yes, absolutely. ***01, ***02, ***03 and ***04.
Old May 14th, 2012, 08:13 AM   #4
What is the duration of the clip? There is a 4GB limit on a FAT32 formatted cards, about 13 min. long, so, if the clip is longer than 13 min. you'll get multiple chunks 01, 02, etc... This is normal, place them on a timeline butt to butt...
Thank you.
Ilya Spektor is offline   Reply With Quote
Old May 14th, 2012, 09:38 AM   #5
The clip is 50 mins long. The whole 50 mins clip is copied 4 times. The 4 copies are identical.
Old May 14th, 2012, 01:40 PM   #6
Do a non clip browser copy and paste to see if the same thing happens. Turn on CRC checking if that's not on.
Old May 14th, 2012, 02:01 PM   #7
I am 99.99% positive you are seeing this in a NLE, maybe Premiere Pro because I see the exact same thing with my EX3's clips, but oddly, not my EX1. You only need to import the "01" file.
To summarize, this is completely NORMAL.
EDIT: well, duh to me. I just saw your info which says Premiere CS5 which is what I use.
Old May 14th, 2012, 03:58 PM   #8
No problem - of this kind - with importing without using the Clip browser, Jack.
Thanks Steve for reassuring me that this is nornal - funny kind of normal, but there you go !
