Best b-roll camera for EX1 at DVinfo.net
Old July 19th, 2012, 07:17 AM   #1
Hello All,
Just wondering what would be a good camera to pair with it, other than another EX1. I was thinking along the lines of a used Z1U or FX1000 or Z5 or something. Most of the time I record one camera shoots with the EX1, however I do multi-camera sports for webcasts and some community television which is in 16:9 SD. I currently have a PD-150, however that really looses quality in 16:9 mode.
Anyone recommend anything in this range?
Mark
Mark Chafe is offline   Reply With Quote
Old July 21st, 2012, 08:04 PM   #2
Re: Best b-roll camera for EX1
This is a common question. Search on "b camera ex1" and you'll find some information. Bottom line it that the EX1 is so sahrt and all, it's hard to find an inexpensive camera that can do that. ALso, there's the EX1 low light performance.
The FS100 is reportedly pretty good. I use a 5Dm2.
Old July 22nd, 2012, 08:06 AM   #3
These days I'm doing a lot of single person, two camera shoots. Not because anyone demands it, but since I'm producer/shooter/editor I find this is the best way for me to make effective videos. I've shot with two EX1s, two Canon T3is, EX1 and T3i, EX1 and Panasonic GH2. My preferred setup is the two T3is. However if I need the EX1 I have no hesitation using the T3i or GH2 as a B camera.
For matching looks I'd probably choose the GH2. I've found the sharpness of this camera similar to the EX1. As far as matching the look I think it's not too bad. T3i is easier to shoot with, but the look is more different and it's a bit soft in comparison. Getting another model of a second camera is always going to make matching difficult.
Brett Sherman is offline   Reply With Quote
Old July 22nd, 2012, 11:21 AM   #4
If you are running DV through firewire into a computer for mixing and live uplink to your webcasts and community television broadcast, then an FX1000 has firewire and will work well for widescreen SD. An FX7 is also a possibility. Although the FX7 has poor low-light performance, that is not as much a concern outdoors, in SD mode or in a well lit stadium. If you do not need firewire, then an AVCHD camera such as the NX2000 might be a better alternative.
Eric Olson is offline   Reply With Quote
Old August 6th, 2012, 10:46 PM   #5
Really I have no preference for format. As long as they match up ok with the EX1. I have noticed a lot of HDR- FX1 going for relatively cheap on ebay and as long as I can get 1080i component out, I could use that, or if need be convert to SDI or HDMI.
I did have a Z1 however I sold that, along with a PD150 to get enough to get the EX1. Would the FX1 be an ok camera as B roll to the EX1, as well as be able to properly display 16:9 for SD footage as well? or are these cameras just too old and maybe an FX1000 be a closer match.
Mark
Old August 7th, 2012, 02:10 AM   #6
1. No hdmi out on Fx1
2. I just bought the nx 70 u. One of the reason is that. A cluple of Ex1 owners said it made a great second camera. For them. From footage only I feel the 70u looks more like Ex than Fx1 which I own.
Chris J. Barcellos
Old August 7th, 2012, 11:32 PM   #7
I expect this is in part because the FX1 uses CCD sensors while both the EX1 and NX70u use CMOS sensors. Note that the FX1000 and NX2000 also use similar CMOS sensors.
