Hot Shoe Adapter for PMW-200 at DVinfo.net
Old April 2nd, 2013, 05:57 PM   #1
I want to use the hot shoe connecter on the back of the camera but I need an hot shoe adapter to slide on the connecter. I don't believe it comes with the camera. Can anyone give me an idea of what the adapter is called or where I could get it. Thanks.
Larry
Larry Kropp is offline   Reply With Quote
Old April 3rd, 2013, 09:06 AM   #2
Re: Hot Shoe Adapter for PMW-200
Larry...the HXR-NX5U has a very similar lay out, Sony includes a 'cold shoe' attachment accessory with the 'NX5' for use in the 'rear' position, but there are four (4) small threaded holes for attaching the cold shoe 'plate'. I don't if the PMW-200 has those threaded screw attach points. If it does, I think the 'cold shoe' plate assembly might be available from Sony? Never hurts to ask.
I hope this was helpful.
Regards,
J.
James Kuhn is offline   Reply With Quote
Old April 3rd, 2013, 09:13 PM   #3
Re: Cold Shoe Adapter for PMW-200
It is. I'll check with Sony. Thanks for the info.
Larry
Old April 5th, 2013, 10:32 AM   #4
Good hunting.
J.
Old April 6th, 2013, 07:28 AM   #5
Larry...I found this on page 137 of the Sony "Solid State Memory Camcorder PMW-200/PMW-100 Operating Manual":
"To attach accessories to the rear accessory shoe, use the optional cold shoe kit (part no.: X-2546-633-1)"
I hope this helps,
J.
Old April 7th, 2013, 08:09 AM   #6
Thanks for the part number, still haven't been able to locate it. Can't find it on B&H either. Will let all know if I find it.
Anthony Trotter is offline   Reply With Quote
Old April 7th, 2013, 09:04 AM   #7
Anthony...Try this.
https://www.servicesplus.sel.sony.co...X25466331.aspx
Old April 7th, 2013, 12:02 PM   #8
Perfect. Thanks so much James I was not finding anything. Thumbs up to the DVInfoNet team! Still not for sure why Sony would put a cold shoe connector on the camera and then not include the adapter to slide on the connector. Go figure.
Larry
Old April 8th, 2013, 07:55 AM   #9
Larry...glad I could help. That's one in a row for me. : )
I think the 1/4-20 screw hole in the 'rear' position is envisioned to be used as a 'Crane' attach point for overhead shots, etc. It's a little more sturdy than a 'Cold Shoe' mount.
Regards,
J.
Old April 8th, 2013, 08:53 AM   #10
Thanks for that, James.
Old April 10th, 2013, 07:50 AM   #11
I just ordered a generic one from bh photo
Rob.
www.rpbproductions.com
robert@rpbproductions.com
HD101/G5 Mac/4gig Ram/1TB HDD/30" Cinema Display/FCP.
Robert Bale is offline   Reply With Quote
Old April 10th, 2013, 09:57 PM   #12
Robert, can you copy the link to the item on B&H and paste it here?
