PMW-320 and Cine4 at DVinfo.net
Old June 10th, 2013, 03:58 PM   #1
PMW-320 and Cine4
I have the PMW-320 and somehow managed to have Cine4 in my SF settings.
I am trying to use the same settings on my friends 320 as well but dont remember how i got the Cine4 setting :) Any ideas and thanks in advance.
Anthony McErlean is offline   Reply With Quote
Old June 16th, 2013, 04:14 AM   #2
Re: PMW-320 and Cine4
Anyone any idea :)
Old June 16th, 2013, 07:15 AM   #3
Vortex Media
Cine 4 is one of the gamma options in the picture profile menus of the camera. Is that what you are asking about?
BTW, if you really want to match two cameras, save your PP to a card and then load it on your friend's camera so you can be sure that ALL the settings are the same -- not just the gamma mode.
MASTERING THE SONY PMW-EX3
Old June 16th, 2013, 03:01 PM   #4
Thank you Doug, yes, that one.
Yes, I looked at saving it to card but wasn't sure how to go about it, ....even after reading the manual :)
Thank you Doug.
Old June 17th, 2013, 06:31 AM   #5
In the "Others" page of the menu, and "Camera Data"
Saves a snapshot of the cameras setup, including assignable buttons, clip naming and picture profiles to the SxS (SD) card.
Old June 17th, 2013, 07:42 AM   #6
Thank you Alister.
Old June 17th, 2013, 04:22 PM   #7
Vortex Media
Just a word of warning. Only use the Camera Data file method if you wish to entirely clone your camera. Your friend may not appreciate you changing nearly every setting on his camera, including zebras, peaking, assign buttons, etc. I'd be pretty pissed off if you loaded a Camera Data file into my camera.
If you only want to give him your picture profile settings, and leave everything else on the other camera alone, then use the PP Data menu instead.
Old June 17th, 2013, 04:28 PM   #8
OK Doug, good point. Thanks
Old June 18th, 2013, 07:14 PM   #9
Duh...my mistake...... It's a PMW-320, not EX1/EX3, the scene files are saved under the File menu using either "all file" which saves everything (with Doug's caveat above) or scene file to just save/recall the scene files.
Old June 19th, 2013, 02:36 AM   #10
:) Thanks again Alister.
