5.8mm wide angle -- ugh!
This camera was looking great until I saw the 5.8mm wide angle setting. That's a real disappointment to me. That's not nearly wide enough IMO. I was seriously thinking of selling my HVX200 and buying this unit, but now I'm really reconsidering. The HVX200 has a 4.2mm wide angle -- MUCH wider than the Sony. I really dislike using WA attachments as well. Why did Sony go with such a limiting setting? A lense limitation?
Bill,
You must take in consideration that the SONY EX has a different size image sensor compared to the HVX. That makes a direct comparison impossible. The HVX200 has 1/3" image sensor and the EX 1/2". Therefore it is an idea to recalculate to the equivalent of a 35mm still camera: HVX: 4.2mm would be 32.5mm (in a 35mm photocamera) EX: 5.8mm would be 31.4mm So the difference is not that bad at all. Regards, Erwin |
Bill,
The EX has 1/2 inch chips as opposed to the HVX's 1/3 inch chips. That means the EX will have a wider view than a 1/3 inch camera at the same focal length. In order to compare on the same playing field, each lens/sensor size combination needs to be converted into the 35 mm equivalent. I don't know the formula to convert 1/2" and 1/3" sensor cameras into 35mm though, but I would assume the 5.8mm of the EX would be very close to the 4.2mm of the HVX. A good example of this would be take a full-size sensor DSLR like the Canon 1Ds-Mark III and a Rebel XTi and fit the with the same lens, say a 50mm fixed. If you had them on tripods right next to each other, the 1D will have a much wider viewing angle than the Rebel at the same focal length. The reason is because the Rebel (and other more affordable DSLRs) usually have the APS-C sized sensor, which is smaller than a full size 35mm sensor. They have a 1.6x magnification factor. So to match the 50mm of the 1Ds, you would have to fit a 31.25mm lens. |
Erwin beat me to it - and with the correct conversion! ;o)
31mm on a 35mm frame is not that bad for wide angle.
Just to toss in the Wide Angle Converter figures.... I think I read it was a
x .8 So with the WA adaptor in place the wide side of the lens would be 25mm that is if you want to use a WA.... I have also heard that with the larger battery, the WA converter balances the camera better....... This could become a consideration as the cam is not a shoulder mount |
Yes, the EX1 is slightly wider than the HVX. You can skip over the 35mm conversion (which applies to the "8-perf" still camera format and not the "4-perf" motion picture camera format) and just convert between the two cameras.
The math is simple - since 1/3" is .333" and 1/2" is .5", divide one by the other to get the ratio. The conversion ratio between the two cameras is 1.5 : 1. So the 5.8mm lens on the Sony is equivalent to a (nonexistent) 3.86mm on the Panasonic. Put a different way, the Sony goes more than 8% wider in terms of field of view than the Panasonic. And this is before attaching the wide angle converter. |
Does anyone know the calculation at a given f-stop and match for field of view (focal length) on how much tighter DOF is on a 1/2" vs 1/3" sensor camera?
I realize this answer would be the science and may not match 100%, but would be close. |
Thanks Paul.
The 16:9 1/2" sensor was not listed as an option, so I based the info from using the 4:3 1/2" and 1/3" sensors. Of course it's all about FOV (Field Of View). Since the 1/2" is wider at a given focal length, the 1/3" would have to go wider (hence more DOF) to maintain the same FOV as the 1/2" camera. If the same distance from the subject using the 1/2" and 1/3" cams are maintained, the 1/3" cam would have to increase its focal length by 25% to match the 1/2" cam FOV. As a result the 1/3" cam would also increase its DOF by 25%. So does this result seem correct? It shows a 25% improvement for tighter DOF (at the same FOV and f-stop) over the 1/3" cams. |
Steven,
Another way to look at DoF among different formats is to think of equivalents. Using the same lens conversion factor of 1.5, it works out that the DoF of a 1/3" camera at a certain stop is the same as a 1/2" camera at that stop number x 1.5, at equal fields of view. As an example, a 1/3" camera at 10mm at f/4 is the same as a 1/2" camera at 15mm at f/6. So a 1/2" camera at the same stop, f/4 has less DoF than a 1/3" camera with the same field of view. Since each f/stop is an increase in number by a factor of approximately 1.4, it can be said that the 1/2" camera has about one stop less depth of field than a 1/3" camera, at a given field of view. All of the above assumes that the circle of confusion spec is also proportional to the lens/chip conversion factor, which it pretty much is in a typical depth of field calculation. It also assumes that the sensor sizes really are what they say they are and are in a 1 : 1.5 proportion - I cannot find the actual measurement spec for the active area of the 1/2" 16x9 chip used in the Sony, nor have I ever found a reliable spec for the HVX (2/3" is widely published as 9.6x5.4mm, for example). If anyone has those exact specs I can revise my numbers. |
