A comparison of the Sony EX1 and the Canon XL-H1 - Page 2 at DVinfo.net
Old December 1st, 2007, 11:28 AM   #16
Michael you are right about the HDLINK HD-SDi as 1080i60 with the progressive embedded with a 3:2 pulldown.
I was hoping there may be another solution short of buy a different monitor.
The JVC reference LCD does not show the jagged vertical motion artifacts.
But, I ran straight SDI out to the JVC; although, this should also be 1080i60 with the progressive embedded with a 3:2 pulldown.
The JVC LCD has faster response for interlace, or is it deinterlacing, I'm not sure?
Old December 1st, 2007, 11:36 AM   #17
I also checked out the camera at Abel in NYC yesterday and second Michael Galvan's observations. I tried an on-the-spot vignette test throughout the lens range and didn't see any dark corners on the monitor, but some reports say it can only be seen on playback.
On an off-topic note, they also had the soon-to-be-released Litepanels Micro on display, which runs off four double-A batteries. It's got a very small form factor, and if it's got sufficient throw for run & gun interviews and B-Cam work, it seems well worth the $330.
Michael Rehfield is offline   Reply With Quote
Old December 1st, 2007, 11:47 AM   #18
You won't see it unless your monitor shows the overscan region.
Try SDI out for full raster.
Old December 1st, 2007, 12:00 PM   #19
Originally Posted by Michael Galvan View Post
6. And of final note, the guys there confirmed that the HD-SDI is indeed 10-bit. Looks like capturing this thing to a 10-bit codec like ProRess 422 HQ with an AJA IO-HD would yield incredible results.
I love the parroting that salespeople and marketing reps do. These people don't do any testing at all. Sure, it's probably 10bit from a standards compatibility perspective, but I've tested the output with the Kona and the SheerVideo 10bit codec, (basically uncompressed 10bit) and it doesn't have the extra smooth gradations you would expect with true 10bit output. It looks just like the H1's output, which is quantized to 8bit and sent out with two bits set to zero.
Barlow Elton is offline   Reply With Quote
Old December 1st, 2007, 01:25 PM   #20
That's interesting, because I specifically pointed that out to them and asked them if the HD-SDI of the EX 1 does the same thing, but the sales guy (who's a cool guy there .. they're all cool and nice) went to ask their Sony rep and they confirmed it as true 10-bit.
Michael Galvan is offline   Reply With Quote
Old December 1st, 2007, 01:30 PM   #21
Well, based on what Barlow has said, I'm questioning it is filling all 10 bits.
If it's not showing as a benefit, it's probably filling only 8 bits.
Is there some sort of software that can extract the stream information and display if it's filling all 10 bits?
Old December 1st, 2007, 01:30 PM   #22
Images: 1
Good to know that you've done some definitive comparison, Barlow. This question was raised early on about the EX1's HDSDI pipe.
-gb-
Old December 2nd, 2007, 04:49 PM   #23
Sounds exciting Michael-we will be eager to hear of your findings. You had some really impressive footage from your H1 on your site- if you can top that, well....
Hayes Roberts is offline   Reply With Quote
Old December 3rd, 2007, 07:34 AM   #24
Thank you Hayes ...
I'll try to see what I can do in terms of what I can record. There is a setup with a lot of colors, but everything will be mostly static.
Old December 3rd, 2007, 07:48 AM   #25
Mike, do you have access to Canon manual 16x or 14x lens, if you do, please take same shots, from my testing 14x produces clearly better color, with more color contrast and similar resolution compared to the stock lens on H1.
Regards.
Oleg Kalyan is offline   Reply With Quote
Old December 3rd, 2007, 10:05 AM   #26
Hey ... sorry, currently I only have the 20x HD stock lens. Maybe they may have one for me to test ...
Old December 3rd, 2007, 11:32 AM   #27
Barlow did you try to color correct the footage to see how much each version would band? They may in fact both look the same when looking at it straight on but it is when to push the CC to extreme levels where the 10bit would shine. Remember 10 bit video still has to display on your monitor as 8 bit.
Old December 3rd, 2007, 01:23 PM   #28
No, I haven't had the time yet. Will give it a try but I did view it on a CRT VGA display and the video card supports 32 bit color.
Old December 3rd, 2007, 08:38 PM   #29
That isn't 32 bits per channel but the total bits.
10 bit video has 30 bits total. If it had an alpha channel it would be 40 bits.
The 32 bits on computer monitors is 8 bits per RGB and Alpha. so it is only 24bits for the actual color or 8 bit per channel.
The video display graphics card is also a limiting factor here since they usually only work in a 8 bit color space. This is why having a HD-SDI based editing system and a good 10 bit HD monitor are so important.
Old December 4th, 2007, 10:30 AM   #30
Yes, I would like to have a real 10 bit HD-SDI montior. I wil say that the banding was much less noticeable on the CRT, but when viewing higher bit depth photos on my LCD, the banding is still way less noticeable than a regual 8 bit pic. And btw, it wasn't bad banding at all, just something I'd expect from 8 bit video.
Thomas, do you have a way to view 10 bit video properly? I'd be happy to send you a couple clips to peruse.
