EX1 with Vegas 8b
Has anybody tried importing HQ 1920 x 1080 25P progressive into Vegas 8B?
The properties list show HQ 1920 x 1080 24P and HQ 1920 x 1080 50i but not 25P |
The "properties list" is just the basic set of ready templates that Vegas comes with. Open the closest one (1920x1080/50i in this case), and customize it by changing field order in the video section from "upper first" to "none"; type in you new template name (like 1920x1080/25p) and save it, using the diskette icon to the right of the name field.
Next time you set up a new project, the saved custom template will be available to you. |
Greg, can't you simply change 24p-template property settings from 24 fps to 25 fps?
--- Alright, Piotr has already answered! |
Piotr, you're absolutely right. The 50i-setting is the closest to modify.
So if i'm shooting in 720/50p,here in pal-land,what template should i use ?
Should it be HDV 720-25p ? Or should i be modifying a template ? HD 1080i-50i always seems to look the best when i'm previewing. Also do these templates make any difference when i'm actually rendering to say mpeg-2 or mp4 or whatever ? What template should i use if i've got 1080 and 720,some interlaced and some progressive,all on the same timeline ? |
Vegas is known for being extremely tolerant with respect to your project properties; what really matters is your output settings. So yes, you can mix all sort of stuff in the same project/timeline; the only caveat being the previewing will not always be accurate. But once you decide on your final format and render out accordingly, everything will be OK.
Thanks Poitr,that's what i thought.
PS glad to see you got your EX eventually. Paul. |
EX1 vegas setttings
Thanks Piotr and others.
2 EX1s ara being delivered to me today. Look forward to reporting my progress. All the people who have and continue to post have built up a good background for me before getting the cameras. That plus Doug Jensens DVD workshop 'Mastering the Sony PMW-EX1' which I can definitely recommend. |
