HD-SDI Output 4:2:2 or 4:2:0? at DVinfo.net
Old March 20th, 2008, 08:35 AM   #1
Forgive me if this was answered elsewhere in this forum. I know the EX records in 4:2:0 but does the SDI output offer 4:2:2 output prior to recording?
JMM
www.jenacommunications.com
Jerry Matese is offline   Reply With Quote
Old March 20th, 2008, 08:40 AM   #2
Images: 10
by definition, HD-SDI is 4:2:2.
It's been confirmed that the EX1 outputs real 4:2:2 at the SDI port and not a 4:2:0 in a 4:2:2 wrapper.
Old March 20th, 2008, 08:46 AM   #3
So this is super clean, uncompressed 8bit 4:2:2 1080p right?
JMM
Old March 20th, 2008, 08:47 AM   #4
Images: 10
according to what I've read. I haven't personally confirmed this. And isn't HD-SDI 10 bit? I think so.
Old March 20th, 2008, 08:50 AM   #5
it can be either 8 or 10
JMM
Old March 20th, 2008, 08:51 AM   #6
Is there something official from Sony on this?
JMM
Old March 20th, 2008, 08:57 AM   #7
Juan Martinez, a high ranking person at Sony US, was quoted in an earlier thread saying it is true 10 bit 422 uncompressed HD-SDI. Do a search, I'm sure you'll find it.
-Sean
Sean Donnelly is offline   Reply With Quote
Old March 20th, 2008, 08:49 PM   #8
8 bit 4:2:0 is what you get on the SxS card. The SDI is 10 bit 4:2:2
Michael H. Stevens is offline   Reply With Quote
Old March 21st, 2008, 12:14 AM   #9
It only outputs 60i correct? For example, if you filmed in 1080/24p and wanted to capture or send to tape via the hd sdi output the camera puts a pull down in it.
James Brill is offline   Reply With Quote
Old March 29th, 2008, 09:32 AM   #10
Are you saying the HD-SDI output will not output a progessive signal 24P, 30P or 60P???
JMM
Old March 29th, 2008, 09:54 AM   #11
Images: 1
Like most cameras that record in 4:2:0 with an HDSDI output, the camera will give true 4:2:2 output only when the signal is taken live from the camera head. After recording, what comes out is 4:2:0 upsampled or wrapped in 4:2:2 in order to comply with HDSDI specs.
In live mode, it's confirmed that the EX1 outputs a true 10 bit HDSDI signal.
-gb-
Old March 29th, 2008, 10:01 AM   #12
Can it output 1080P from the HDSDI with 422 space before recording??
JMM
Old March 29th, 2008, 10:20 AM   #13
Someone correct me if I'm wrong, but I believe it's standard for HD SDI to pump out 1080P at 1080i with pulldown.
In fact, this is how data is stored on DVDs. 24P Movies are encoded to DVD interlaced with pulldown. Progressive conversion can be performed digitally inside the progressive player. Since DVDs must have the ability to display interlace, they must be stored in that format.
Old March 29th, 2008, 10:33 AM   #14
Images: 1
Steven, I'm fairly certain that you can author a DVD in true 24P without pulldown. This is an old trick for gaining about 20% extra capacity on a DVD. The player will create the pulldown to 60i upon output to the TV. The extra capacity can then be used to fill out the space with a higher quality encode or, keep the same quality and add more running time to the program.
-gb-
Old March 31st, 2008, 06:14 AM   #15
4:2:2 1080p or not...
Still looking for a clear answer here.
Does the EX output true 4:2:2 1080P from the HDSDI port?
JMM
