List of EX1 faults and how to check for them?
Can we compile a list of the various faults the EX1 has as a sticky, combined with instructions on how to check for them? For instance, a step-by-step on how to check whether one has a backfocus fault.
I thought this might be easier for people to check what faults there cameras are exhibiting, thus when sending there cameras into Sony for repair, all faults can be addressed at the same time (we hope). It would be very annoying to send our cameras in for repair, getting it back only to discover another fault because we weren’t personally aware of it. Regards, Simon |
Sticky pleaaase
Vignetting issue:
point the camera at a wall or something with an even light color. Zoom in and out and look if you have any vignetting around one of the corners of the image troughout the zoom andback. |
Autofocus, flicker, color shift issue:
Set the camera to manual apart from focus, which should be set to AUTO. (My settings were as follows: HQ 1080 24/25p, 1/50th, f/4, gain -3, manual white balance.) Point the camera at an object with a bright light behind it, like some trees. If you are experiencing the same you should get a pulsating light flicker in the bright areas especially around the trees, the image will go in and out of focus rapidly (not to be confused with focus hunting) and there is a color shift in the bright areas. Example |
Battery drain issue:
Leave the battery on camera for approx. 24 – 48 hours with the camera switched off, if you have this issue, your battery would have drained significantly. Can someone please confirm for sure, whether this happens with the large battery. |
Simon, did you get a response from Sony regarding this issue? Has it been fixed?
No not yet, they've acknowledged that there's an issue and said they've sent it off to Japan but that was 2 months ago. I've chased it up but am told they've not heard anything back. As soon as they do, I'll post. Quote:
Your assumption is correct, the battery will be fine. As for the settings, they will be fine too, I believe the internal battery saves these settings. |
The battery issue I believe is across all EX-1s so don't try to send it to Sony to get fixed. Its annoying I guess, but not really a big deal considering. A firmware update may possibly fix it but I like to be in the habit of taking off the battery anyways when I put it in the bag, as I have had the power switch get toggled on. And no, you definitely will not lose any settings.
I have kept my battery on for 48 hour straight and it has gone down by maybe 5-10 minutes. I have v1.05 firmware |
Simon, i think this flicker is maybe do on AUTO KNEE ON in profile. Try off or set manual.
Don |
- Don |
Could one of the mods sticky this thread so that it can referenced with easy by newbie owners of the EX?????
