1080p and ProMist filters
Given the higher resolution of the EX1, are optical FX filters such as the Black ProMist still better than post processing effects? I don't own such a filter, but I'd like that "interview" look.
Promist filters can sometimes show the pattern of the filter at deep stops on wide lenses. Schneider just released a new line of classic softs for HD use. could be very interesting...
-Sean |
The first is a diffusion filter also known as Promist or Black Frost. Promist filters are made with a particulate that while black in color still retains a reflective surface. This means that black tones will turn a milky gray color due to contamination from reflections off of the particulate. On the other hand, Schneider Black Frost filters are similar in design but use a non-reflective particulate that does not spread light into the black tones and retains rick black levels. This is a useful filter for diffusing wrinkles or other high frequency details. The second type of filter is a filter that effects resolution. This is our Classic Soft filter. It creates In-Focus Diffusion that reduces the resolution of the image by creating a second plane of focus with our micro lenslets which are drops of optical cement. Our new HD Classic Soft filter is designed to be used on small HDV Cameras with 1/4, 1/2, 1/3 sensors. The reason for this is that our standard Classic Soft filter has lenslets that are too large for HDV use and can be imaged (looks like you have water spots on your lens) at smaller apertures (generally f11 and higher). Both filters are usable for interview shooting. The HD Classic Soft will create a nice soft appearance to skin and give a pleasing soft glow to highlights. The Schneider Black Frost filter will blend wrinkles and take the 'HD Edge' off of the footage and make it appear more film-like. The combination of the two is unstoppable and has been used on many major feature films and is currently the preferred look in Hollywood. Ryan Avery Schneider Optics |
Thanks for the info Ryan. Are either the HD Classic Soft or Black Frost available in a "thin" screw-on version that would fit under the EX1's screw-on lens shade?
Do these come in 4x5.65 for the matte box? |
Choosing most appropriate filter strength
Ryan - When perusing the Schneider Black Frost filters on the dvinfo.net sponsor websites, they offer many different filter strengths. The websites do their best to display the differences between the filter strengths but is very difficult to see the precise differences except from min to max via the web graphics. Can you provide any "general" guidance regarding the use of these filters regarding focal length and filter strength for interviews?
Using this filter on the lens without a matte box but still using the hood would be great for difficult "on the spot" interviews. Thanks a bunch! TG |
Avoid Lens Flare
When using any kind of diffusion/pro mist/softfx filter, take special care to shield the camera lens from extraneous light sources or open sky. Your footage will look washed out/lose contrast other wise.
Good matte box , flags, cutters can help maximize the look these filters can deliver. Getting off my soap box, now. |
Stick with the 1/4 and you should be happy with the look unless you are trying to decrease wrinkles and heavy make-up. At that point, use the 1/2. Ryan Avery Schneider Optics |
