Viefinder problem !!
The viewfinder is very poor on this camera. I have found by lowering the brightness the picture is inproved !!! Buttttt Both my camers will not store the setting. Is there a firmwere update for this thanks Barry
I don't think anyone uses the EX1's viewfinder. It's worthless - and the LCD is so amazing I don't miss the viewfinder.
Viewfinder
I have a Z! and no way is this viewfinder as good ! The EX1 has a strange peaking that puts a white halo round things why? and will not store brightness settings. Will a firmwere update fix this cheers Barry
1) doing a side by side comparison with peaking off they look much the same to me (neither good). 2) my EX stores the EVF settings OK 3) the peaking just highlights the edges in focus, so that can look like a halo. Try reducing the intensity of peaking. Or the colour, if you don't like white. The only point is that you can shoot using the EVF, but you can't rely on it for focusing or more than seeing what is in frame. It is likely that in run-n-gun that auto focus would be more reliable than manually using the EVF, even with peaking on. The LCD offers far greater utility. |
With respect to Serena who's advice has benefited me on several occasions FOR THE LOVE OF GOD don't leave the EX1 on auto focus in a run-n-gun situation. I understand that Serena's trying to steer you away from using the EVF but the EX1's auto focus will not just disappoint - it will stab you in the back! I shoot reality shows, mostly of the cop variety and I can guarantee the auto focus will stitch you up if you give it the opportunity. I've found the auto focus on the EX1 to be unreliable in every shooting condition regardless of aperture, available light and in a variety of light sources. Even in bright sunlight at f8 I've seen the auto focus 'hunting' on scenes where there's been some clear vertical and horizontal lines and flat surfaces to focus on. I totally agree that the EVF is a waste of space but why not use the LCD? I like to keep the camera nice n high so eyelines are more accurate and I find the LCD works great. Why not use it?
I also have a Z1 and I use the EVF a fair bit, I hadn't noticed that it was really bad but then the LCD isn't very good either. Cheers Mal |
I'm sorry to read the auto focus is not good. In my limited use it is undependable.
The problem is, you can't use the LCD in every situation either. You can't see it in bright daylight. A viewfinder remains indespensible, no getting around that. |
