October 23rd, 2008, 01:17 PM | #1 |
EX3 Cheek Guard Poll
I'm trying to get a sense of whether or not people are using the cheek guard on their EX3. I put mine on while unpacking it, and within a day I removed it. I felt is was not useful.
Now that fabrication has begun on a new EX3 shoulder mount, I realize that we will either need to design it to accommodate the guard, exclude the guard, or also manufacture a spacer so that they guard is optional. Please let me know - do you use the cheek guard? Thanks!
Sony EX3, Vegas 9.0 64bit, Windows 7(64), Core i7, 12GB, RAID1 & 0, HotSwap SATA, 30" LCD(2560x1600)-GTX285 & 24" LCD(1360x768)-7800GT |
October 23rd, 2008, 01:58 PM | #2 |
I don't find it useful except as a kind of added battery cover when folded over. Will probably take it off again.
Dan |
October 23rd, 2008, 02:16 PM | #3 |
In my opinion the plastic cheek guard was a cheap afterthought by Sony and I've never used it.
My guess is that those doing studio work (with all the cables plugged in the back of an EX3) might use it - but I'm still doubtful....anyone?
Andy K Wilkinson - https://www.shootingimage.co.uk Cambridge (UK) Corporate Video Production |
October 23rd, 2008, 03:06 PM | #4 |
I never liked the idea of the guard, so it is still in the EX3 box. How much longer before your base plate is ready for sale Ted?
Thanks very much.
David Issko Edit 1 Video Productions |
October 23rd, 2008, 04:54 PM | #5 |
I don't mind the guard.. Do you have any drawings you can post just to give us a taste..of your plan? And are you adding a shoulder support?
October 23rd, 2008, 06:39 PM | #6 |
I only kept it in case I decide to add something to the back of the EX3... I can drill it into the gaurd or something... but it is just sitting in a box right now, same box as the viewfinder scope thingy.
October 23rd, 2008, 07:37 PM | #7 |
I'm expecting a rough prototype in the next two weeks. Perhaps another two weeks for production?
October 23rd, 2008, 08:57 PM | #8 |
Not going to use it.
Still 'in the box', so to speak. And will likely stay there once I add a 3-point plate.
[Use the viewfinder regularly]. Jus. |
October 24th, 2008, 01:04 AM | #9 |
Thanks Ted.
Sorry to be a pest, but what would you expect the cost for us end users be please? Special rate for DVI members? Thanks
October 24th, 2008, 03:06 AM | #10 |
Use mine, makes the camera much more stable when hand-held. Wasn't going to use it as it does look a bit of an after thought, but after using it for a bit I do find it stops the camera wobbling from side to side.
Alister Chapman, Film-Maker/Stormchaser http://www.xdcam-user.com/alisters-blog/ My XDCAM site and blog. http://www.hurricane-rig.com |
October 24th, 2008, 04:26 AM | #11 |
I agree with Alister. I use the EX3 for shoulder work 100% of the time and find the cheek pad indispensible for stabilisng the camera.
October 24th, 2008, 08:14 AM | #12 | |
Probably, if you have those batteries, you already have a mounting plate laying around. Therefore, a slight modification will enable you to mount it on the camera plate.
October 24th, 2008, 12:42 PM | #13 |
Stereo headphones and cheek pad
I am going to remove mine. It’s in conflict with my headphones. Or, perhaps modify it, make it a bit shorter.
October 25th, 2008, 01:58 PM | #14 |
The cheek guard is clearly a cheap afterthought, nevertheless, it's useful. As Alister says, it gives added stability and prevents some left-leaning.
Keep it up, Ted, and keep it simple. Sounds like a great idea. |
October 29th, 2008, 10:03 AM | #15 |
Ted,
Is there any way you could have an option for a bars interface? I have one already that I can supply pictures and a hole location diagram for if that helps? Also if you can supply a v-lock power plate could you make sure it has both a d-tap and at least one hirose connector (like the bebob) please? Thanks Dan |
