MxR Expresscard Reader moves from final QC to Shipping - Page 9 at DVinfo.net
Old January 11th, 2009, 11:05 AM   #121
But think of the hurdles.
PCMCIA interface would have little use beyond P2 and older computers
DVCProHD is 100mbps compared to XDCAM 35mbps. It seems Convergent Design can handle 100mbps using Flash cards though.
Originally Posted by Ross Herewini View Post
Hi John,
What's P2?
Only joking....
That's a great idea, we'll have a look to see if there is something we can do, but we have a few announcements coming up in the EX1 area first....
Old January 12th, 2009, 04:33 AM   #122
I use an imac .. no PCI Express slot & have been frustrated unloading large files from 16 GB Ultra ll cards via DigiCard USB SD reader.
So recently took a punt & ordered a MicroU2E-MV USB 2.0 - USB ExpressCard 34|54 Adapter to try with MxR adapters with Sandisk 16 GB Ultra ll cards.
Works a treat - plug in MXR with Ultra ll card .. very much faster than the SD reader - currently $34 US from: PC Card, ExpressCard, and FireWire Devices, Synchrotech
Chris Norman is offline   Reply With Quote
Old January 12th, 2009, 10:37 AM   #123
Can you be more specific? I use Sandisk 12 in 1 reader for SDHC and I get 2x with ClipBrowser CRC on and 4x with CRC off. I can't imagine getting much faster than 4x.
Old January 12th, 2009, 03:43 PM   #124
Using MicroU2E-MV USB 2.0 - USB ExpressCard 34|54 Adapter with MxR, I timed transfer of 3.87 GB file - 210 seconds = Approximately 18.42 MB per second.
Old January 12th, 2009, 04:08 PM   #125
With or without CRC checking in ClipBrowser?
That's about the same speed I'm getting with my Sandisk 12 in 1 reader with CRC off. That's about 4x.
Sandisk ImageMate 12-in-1 Reader Writer SDDR89A15 in Flash Memory Card Readers at JR.com
The Sandisk Ultra II is rated at 15MB/s read but I've tested them to about 19MB/s
which is what we're both getting more or less.
I guess the one advantage is you don't have to take the SDHC our of the MxR.
Old January 12th, 2009, 04:20 PM   #126
Sorry, not very familiar with Clip Browser CRC function, I mainly use XDCAM Transfer app .. yes it is a small convenience not having to remove the SD card.
yeah
Old January 12th, 2009, 04:35 PM   #127
BIG MISTAKE if you're not backing up your BPAV folders!
Transfer app rewraps to MOV. You're going to have a tough time handing those off to a non Final Cut Pro user (and it WILL happen unless you're only doing your own projects).
You also run the risk of a corrupted copy which is what CRC checks for.
You're also going to run into problems if you have a clip spanned across multiple cards.
yeah
Old January 12th, 2009, 06:09 PM   #128
Thanks for tip , but I always archive BPAV if it's important footage.
Old January 13th, 2009, 08:10 AM   #129
10 out of 10 for Ross
Just to say that 10 MxR cards arrived today - and the 10 cards work absolutely fine in my EX1s, thank you Ross. Have married them with 10 Transcend 16gb cards and test recorded them all.
Bruce Rawlings is offline   Reply With Quote
Old February 19th, 2009, 12:22 PM   #130
Hi Chris,
When we ended our testing phase on the MxR Expresscard we realised we had nothing to put the card into to protect it, or just as importantly make it look good in front of our corporate clients.
So we're producing a case based on the existing Sony SxS case, but instead of being dull dark grey it's bright ORANGE, so you can find them in a hurry, especially in the dark.
It has it's own label you can write on, so the idea which is a carry through for us from our DVCAM days, is to number each MxR and the case and then write only on the case.
They should be available in about 2-3weeks time.
We did look at cases for holding multiple cards at a time, but we couldn't get a consensus amongst ourselves on whether a multi-card holder would be soft or hard case, or even how many it should hold.
If anyone has a preference, ie
Soft vs Hard
No of cards
Other stuff we haven't even looked at..
let us know and we'll see what we can do.
Any further word on a case for the MxR cards? And also possibly - labeling suggestions for the MxR adaptor itself?
Barry J. Weckesser is offline   Reply With Quote
Old February 19th, 2009, 12:51 PM   #131
Ross
As far as MxR card holders and cases go, I'd suggest you looked at the Pelican series of SDHC card holders. Of course, they're Pelicans, so waterproof, etc., but they're incredible pieces of gear - bar that one Achilles heel that all of these bags and cases seem to have - and that is that you've got to put a piece of gaffer's on the top of it to identify which one is which.
I have four little Pelicans and four of the little Case Logic soft zippered cases. The Pelicans take 2 rows of 4 cards, the Case Logix, 2 rows of 3. Everything is black. No space or provision for labeling.
You can see how things can get confusing, especially fir the DIT who's doing all the handing out and collecting of cards...
So yeah, yellow! fantastic! hard cases please - think "dropped from 3ft (pocket height) an average of 60 times a day". Think label space - or at least a flat spot for the gaffer's tape. Think waterproof or at least moisture proof.
Maybe Pelican will get their act together and come out with something?
But until then...
Cheers!
Chris
"The content, not the container."
Chris Leong is offline   Reply With Quote
Old February 27th, 2009, 08:40 AM   #132
EX-3 update to firmware
Hi Ross,
my Sony PMW EX-3 the firmware is v1.02_0078
How do I update to firmware of the EX-3 to use MxR?
And to firmware it be not updated, doesn't MxR work?
Thank you
Eduardo Castelan is offline   Reply With Quote
Old February 27th, 2009, 09:53 AM   #133
Originally Posted by Eduardo Castelan View Post
Hi Ross,
Thank you
As I mentioned in your post; you don't need to update the firmware on the EX-3 to use MxR Cards. It's the EX-1 that needs a firmware update. I use the MxR Cards without issue on my EX-3 and I haven't updated my firmware.
Paul Inglis is offline   Reply With Quote
Old February 28th, 2009, 03:20 PM   #134
Sponsor: eFilms (MxR)
Hi Ross,
Thank you
Hi Eduardo,
I have tested the MxR against the latest version that is being installed here in Australia, as of Thursday this week, and it was version 1.03-0082 and it worked fine.
As others have said you won't need to update the firmware on the EX3, as it is a newer camera, and it already allows USB to talk to it.
But if you do decide to go to a later revision, it works fine.
Ross Herewini - E-films
Makers of the new MxR Extreme
Ross Herewini is offline   Reply With Quote
Old February 28th, 2009, 03:34 PM   #135
Ross,
I have just received an e-mail saying... that you are no longer selling the MxR cards? I was thinking of buying some more off you.
Graeme
Graeme Fullick is offline   Reply
