experience with 2/3 CanonHJ18ex28biaseHD lens
Is there someone with experience with the EX-3 combined with the canon HJ18ex28biase HD lens on it.
Now I use a Canon XL-H1 with a sigma 50-500 mm and I want to increase the quality of the image. I think the EX-3 with the canon HJ18ex28biase is a very good comination. I hope someone has some experience with the EX-3 with 2/3 HD lenses. Thanks a lot. |
2/3" lenses are not always the best match for the small photosites that a 1/2" sensor has. You should try to compare a dedicated 1/2" HD lens and the HJ18. I have the Canon KH20x6.4 which is a budget lens and not the greatest lens in the world. However when put up against much more expensive 2/3" HD lenses it does hold it's own, especially if you can keep it between f5.6 and f8. Dont forget that if you want to go to 2/3" you will also need the Fujinon adapter, which is not cheap.
Hi Alister,
Thanks a lot, The main reason for the canon HJ18ex28biase is the tele-effect for filming small birds. I hope this lens will work faster and sharper than my older Sigma 50-500 mm. Tomorrow I'll test the camara and fujinon adapter and lens. I'll post the results on this forum. |
Looking forward to hearing about your tests.
Alister, I think the cost of the Fujinon adapter will be a bit insignificant compared to the £25000 lens!
I've used the 18x28 a lot on Varicams etc., and it's fabulous, sooo useable compared to the HJ40. Sharp even at full reach on 2x. Says it doesn't need lens support but it does really, mainly to stop wobble by touching lens to focus. Agree with Alister on the possible disappointment with 2/3" lenses on smaller sensors, especially if you use the 2x as that's an intermediate optic, plus the Fujinon adapter has glass in it, sounds like too much extra glass to me. Steve |
The extra glass in the adapter is essential as it compensates for the smaller prism in the EX3. At the end of the day the light travels through the same amount of glass in a 2/3" camera or the EX3 plus adapter. |
With 2/3" glass on the EX3 I look upon it as being a purchase of a 700 but spread out a bit more. I'm loathe to invest in 1/2" glass. Much rather have 2/3" that i can use on a wider range of cameras. At the moment I'm eyeing an HJ11 as it is one of the few zoom lenses that I have ever been impressed by.
Hi All,
Everybody a merry Christmas. Yesterday and today I do some tests with my sony EX-3 and canon HJ18ex28biase lens. Everything works fine. The picture is very sharp and good-looking, even with the 2x built in extender. The tele effect is very great (normaly 500/1000 mm and now on a 1/2 inch camara even more). Because of that you will need a very good adapterplate for your tripod. There is noting wrong with the glass into the adapter. Because of the tele effect it is differcult focusing. Next days I will do more tests. |
Hi
Is it nesessary with some kind of support for the lens ? Will the picture wobble when you are focusing? I am considering the big canon 40x contra the 18x28 lens. The tele factor will be close the same and I rare use the full zoom factor. |
With a big lens like that on an EX3 you really should be using some decent support rails as without them you are going to be putting a really big load on the tiny EX3 tripod mount. It would be just about impossible to get the whole rig stable without rails.
Rather than rails I tend to like to use a metal plate. Just an 18" length or so of 2" wide aluminium screwed to the base of the camera, then make spacers for your different lenses.
Bo, the HJ40 is not the nicest of lenses to use, it is just so big and heavy, and a real problem I've always found is that the focus ring is so big it's difficult to get a good grip on it to turn it gently and accurately. I've used a focus demand with it but you never seem to be able to get such a precise feel with a demand. The HJ18x28 is far and away my favourite wildlife lens now (and many others agree with me). It does need some support to help stop it shaking when you put a hand on it to focus, and you do need a decen tripod head (choice head at present is O'Connor 2060, but Ronford Atlas 30 and 2004 are also good). The problem with the adapter for the EX3 I wonder about, is that you've then got quite a few bits of glass to go through then, notably with the extender, I noticed it when I used an F355 with a Fujinon 2/3" HD lens via the adapter, once the 2x was on it started to look pretty yucky. Simon you may already be aware but Vreative Video have a couple of used HJ11s for sale. Steve |
Oh, and don't get too excited about the Image Stabiliser on the HJ40, it's not that big a deal. Certainly it'll help with a locked-off shot in strong winds but you can't do any sort of move with it/following action etc., as it'll be all over the place as the IS tries to compensate for your pans and tilits - makes you idzzy very quickly!
Check my post http://www.dvinfo.net/conf/general-h...ipod-head.html to see just what a beast the HJ40 is! Steve |
We use the HJ40 for our airshow shoots and it is a great lens, but it certainly isn't a portable lens, more like a slimmed down box lens than an ENG lens.
Re: experience with 2/3 CanonHJ18ex28biaseHD lens
Hi,
a bit late for this topic, but anyway. I also have a 18x28 and am wondering if there is a 15mm rod support system for it on the market. There is no thread on the lower side of the lens to mout a support (like on an HJ40), so what support do you use? Just a V or U- shaped bracket? Steve and Alister are writing about such a support thing. In the moment, Im using it just bare on an HDW 730s. Thanks for your help, Steffen |
Genus make a lens support for 15mm rods that has a pair of small rollers that will sit under most lens barrels or it has an adjustable threaded support. Genus Lens Support Bracket G-LSP - Adaptor Bars - Genus Video and DSLR products
ALister |
