Component Out: no Sound and B&W picture
When I connect my EX3 to a SD television,
with the mini-D component out connector, I only get a Black and White picture with no sound, the settings in the "VIDEO SET" menu: YPbPr/SDI Out select: SD YPbPr/SDI Out Display: On Video Out Display: On any ideas? Greetings Jan |
Well,
Since component video doesn't carry sound, that makes perfect sense. In terms of black and white video, component gives red, green, and blue. So even if one or two were misbehaving, you'd not get black and white. Might want to check the settings on the TV to see how it's processing component in signals. |
May be that your SD TV input is actually YCbCr vs YPbPr.
Edit: are you sure your TV has component in? You're not hooking the Green to Yellow, Red to Red and Blue to white or somthing like that? |
Ya know, this gives me the opportunity to rant about Monster and other high priced cables.
"Oh, component is high def--you need expensive connectors and stuff" Wrong! Let's take a 1080p picture. The scan rate is 67.6 kHz (I hope, I copied that and didn't do the math). Audio cable will probably do that! In fact, I really doubt the RGB cable the cable company supplied with my box is anything more than well shielded audio cable. "Well, you need expensive cable for digital" Hmm. No, over short distances, a digital signal is extremely forgiving to impedance mismatches. Just for giggles, I ran a SDI signal through an analog patch bay and non-digital rated RG-59 cable. I looped the ends of video snake through the patch so I had a bunch of analog rated connected. At some point, the eye pattern started looking fuzzy but it always made it to the end of the cable and produced a viewable picture. <off soapbox> |
Well Andy you've given me a chance to rant about people who don't do their maths :) I'll trust you when you say that the scan rate is 67.6KHz. That's the frequency of the horizontal deflection. During that time 1920 pixel worth of data are carried. Do the maths of 1920 x 67.6KHz and you'll get a frequency a long way over the audio spectrum. A SD composite video signal needs roughly 6MHz bandwidth, pretty obvious that HD needs more than that. Composite video is more demanding. Any difference in length or impedance of the 3 cables is going to cause a delay to the three components. You can guess what that does to the image. I agree there's a lot of hubris over cables and for very short runs anything could work without too obvious signal degradation but that is not because the signals are just outside the audio spectrum. SDI over short runs is far more tolerant as it is digital, composite isn't. |
The cable is just copper wire. It doesn't know or care what kind of signal is on it. Sure, at some point the high frequency attenuation will become too great for a particular wire and a particular signal. Quote:
