stock with EX camera
I have the opportunity to acquire some unique stock footage with my EX camera.
The whole MXF, wrapper, .mov, Avid, FCP, Premiere, etc stuff is a bit confusing. I'll need to collect this footage into a format that will be easily distributed in full hi-rez files for use on any edit system. I don't want to get tied down with a format that won't be easily injested by any system. so how do I store my files to accomplish this? |
Why should this be confusing at all?
Save the source BPAV and allow the editor to wrap to MXF, MOV or use as MP4 depending on their NLE of choice. |
^^^What Craig said^^^^ The BPAV folder is the format the camera uses to store your clips on the SxS card. Save that folder (in it's entirety) and you'll have the best chances at being future-proof.
with stock photography, who knows what the editor will want or accept. I'm already seeing resistance to using my EX by some editors. Yes, I think they are stupid, but I can't fix stupid.
So I want to be able to give any client worldwide a simple video clip in full 1080P video they can use without trying to explain rewrapping files they may not understand or know about. KISS. |
But the answer is simple; just have all editing software standardize on one format for HD, across platforms. But wait... they all already support a common format: uncompressed!
Problem solved. As an aside. Editors that don't know how to handle footage from different sources are no pros in my book. Offer a conversion service for them. Then you can use the native format for your footage. And the native compressed 35Mb/s MPEG2 may not be up to par for all stock footage buyers/retailers to fit into the highest HD categories. The best way to get around that is to use an external recorder from the SDI like the CD (nano)Flash or the AJA Ki Pro. George. |
As for the highest categories, I can't please all the people all the time. if they need the footage, they'll buy. I could use the same logic on the file formats but I'm trying to eliminate that from the equasion. Am I to understand that there is no way to get the full 1080p without the bpav folder and all the unwrapping stuff that comes with it? Nanoflash is not in the equasion, sorry. |
Ed this is really a "no win" situation.
You can certainly convert to 10 bit Uncompressed 4:2:2 but you get complaints about the large file size and .mov vs .avi. Then if they need to downconvert to something else the file is going to take yet another quality hit. You could convert to Apple Pro Res since Apple now has a free decoder for Windows. That'll give you a smaller file but Windows editors may not be aware of the free plugin. You could convert to XDCAM HD .mxf but you're dropping the file aspect ratio from 1920x1080 to 1440x1080. Convert from XDCAM EX to DVCProHD and you're going to have a quality hit. A PROFESSIONAL editor will want the MASTER file and do their own conversion as needed. You can't offer what doesn't exist. All you can do as offer to do a file conversion as an add on expense. Even the NASA charges for dubs for tapes of their public domain video. |
Then there's Animation codec or Targa files. The After Effects folks will love you and you'll be cursed by everyone else.
Using something other than the native codec+format will always result in (some) loss and/or (storage) inefficiencies. It can also be time-consuming. You can't go better than native; rewrap to either mxf/mov or both and all more-or-less current applications will be able to work with it directly. It is fairly common to provide proxy-size files as quicktime. George. |
"rewrap to either mxf/mov or both"
I have no post experience so even this is not entirely clear to me. If I take an original clip with the bpav folders and re-wrap to a .mov what happens to the picture quality? Can't all common edit programs today use this .mov format? If I retain all the information within the bpav folders, can I do a re-wrap to whatever file format is requested with the clip browser? And burn that to a DVD or Blu-ray disc for distro to the buyer? |
I make an archival copy of all my BPAV folders as I pull them off the SxS card. They get labeled and put on a hard drive. I edit from a separate copy. You can send that BPAV folder to whomever is buying your footage and they can ingest into into their system however they like. |
Best wishes |
