May 30th, 2010, 07:54 AM | #1 |
Will Tiffen T1 filter reduce CA from stage lighting?
Haven't used the T1 on my EX1 yet, but was wondering if it will help reduce the CA that occurs around the edges of stage lit actors and objects. Have a shoot in two weeks.
Thanks, John |
May 30th, 2010, 08:51 AM | #2 |
Hi John,
Chromatic aberration will not be brought down with the TIFFEN T1 IR filter. It could be a list of things playing into it. First thing I would test is using Oliver Neubert's picture profile shown on this page (show's right now as post #506). Second thing that could be playing into it is your aperture. Oliver's picture profile should help out in allowing you to get in the right aperture range/speed setting. I've used his picture profile on a few "stage" shoots and it has worked really well. Thanks Oliver! One thing I will mention about Oliver's profile is the tonal range does gets crammed up a bit. The image is usable as is. However, to get the full benefit of his profile you will want to spread out the tonal values with some grading/color correction. Failing that you should test out a picture profile using the Std 4 gamma as opposed to one of the CINE gammas and invoke the knee to bring the whites down. Hope it works out. -Andrew Last edited by Andrew Stone; May 30th, 2010 at 11:37 AM. |
May 31st, 2010, 06:32 AM | #3 | |
Personally I'm sticking with using the 486 rather than the T1 for stage shows. I'm never wide enough shooting a stage show for the slight green vignette to be an issue and the light loss through the T1 and the uncorrectable caste it creates is a real problem. |
June 1st, 2010, 12:14 PM | #4 | |
I am already using STd 4 Gamma, but will try that PP. John |
June 1st, 2010, 12:16 PM | #5 | |
Thanks, John |
June 1st, 2010, 04:16 PM | #6 |
Can anyone confirm that the T1 77mm screw-in is only available as a thin filter, thin enough to go under the lens hood of an EX1.
I've looked for a website reference to different types of the T1 and I can't see different types. Cheers folks, Duncan.
FCPX/LS300/EX1/FS100/GoPro/Vinten/HotHead/Jib/Track/Dedos/Lightstorm/Coollights |
June 1st, 2010, 04:51 PM | #7 |
You will not find unanimity on this point. Some argue a solid white balance gets rid of the green cast (there are at least a couple of threads on this issue). I am going to be using it within the next week and doing some tests over the next few days.
June 1st, 2010, 10:24 PM | #8 |
I have a 77mm T1 . It is not a "thin " filter but a normal one with threads on both sides and it does fit behind the EX-1 hood as do most normal 77mm filters. "Thin's" are not neccessary.
Re the 486 - except for the vignetting it is a better solution however I don't think there is any way to remove the green vignette in post that I know of. |
June 2nd, 2010, 02:16 AM | #9 |
Thanks Leonard,
I've got a Schneider thin daylight clear filter in already, but I'll ditch that and try a T1. Cheers, Duncan.
June 2nd, 2010, 08:16 AM | #10 | |
Thanks, John |
