Chromatic distorsion on a PMW200
1 Attachment(s)
This is from a PMW200, full zoom in - looks totally unacceptable to me.
Is this normal, and if not, is there something I can do apart from sending the unit back ? Thanks ! |
Re: Chromatic distorsion on a PMW200
Cannot say what is normal for you camera - but it is a problem that I know of with very expensive cameraes and lenses when filming high conrast - like some dark things against the white sky!
At higher zooms, the CA does indeed increase. If the center of your image has massive CA, I'd send it in. If it's diminished in the center and dramatic at the sides, this is somewhat normal at full zoom.
1 Attachment(s)
The two shots are not taken under the same conditions. The one with CA are the sky white and the light comming against you - that will create CA - the other one are with blue sky and with light coming from your back.
Well - as far as I can see :) |
