F3 S-Log question at DVinfo.net
Sony XDCAM PMW-F3 CineAlta
Old December 21st, 2012, 08:54 AM   #1
F3 S-Log question
Quick question so that I don't have to do a test. If I shoot S-Log out to an external recorder can I record straight non S-Log to the SxS card? I kow I can record a LUT to the SxS, but I never tried to record non S-Log to the SxS while recording S-Log out.
Gregory De Tennis is offline   Reply With Quote
Old December 21st, 2012, 04:01 PM   #2
Re: F3 S-Log question
That is what the LUTs do is give you an approximation of what the image would have looked like if you were shooting in a non s-log mode.
http://www.LandYachtMedia.com
Old December 22nd, 2012, 07:49 AM   #3
I found the answer to my question. Which is NO, I can't record non S-Log, non LUT footage to my camera while recording S-Log to an external recording device. Kinda what I figured.
Old December 22nd, 2012, 11:44 AM   #4
If you use the 709 (180) Lut then the SxS recordings will be the same as if you used the Rec-709 gamma curve with a fixed knee at approx 87%. Pretty close to the cameras standard factory default settings. Slightly under saturated though.
Old December 28th, 2012, 06:46 PM   #5
Greg I also answered your question posted on another forum, and there too I said that you could use REC709 LUT which would give you a "non-slog" version that can be recorded.
So the answer is "yes".
But for example you can't record "cinegamma 2" to SXS card while recording SLOG out.
Hope this helps,
Dennis Hingsberg is offline   Reply
