UV or clear filter for F350? at DVinfo.net
Old November 26th, 2007, 04:01 AM   #1
Can anyone recommend a low profile UV or clear filter for the F350 that wont affect the HD picture i.e. soften it?
I have a Fuji XS17x5.5BRM-M38 lens with 82mm filter thread.
Paul.
Paul Gale is offline   Reply With Quote
Old November 26th, 2007, 11:37 AM   #2
Almost any good quality 82mm UV or clear glass should be OK. So long as the glass is optically flat you shouldn't have a problems. I have a Tiffen that I use most of the time and a couple of cheap ebay clear glass filters that I use when I know I'm going to be in dust and dirt as I often end up scratching them.
Old November 26th, 2007, 11:46 AM   #3
Do you have a low profile Tiffen UV filter - if one is available? (I couldn't tell from the Tiffen web site) - do you get any vignetting on full wide with your lens?
Old November 27th, 2007, 06:46 AM   #4
I have a standard thickness Tiffen, my lens is a canon KH20x6.7 so not as wide as yours but I don't get any vignetting. The ebay filters are low profile. The only problem I have with then is that they are not coated so sometimes you get reflections. Hoya do some good low cost(ish) low profile 82mm UV filters.
Old November 27th, 2007, 06:48 AM   #5
Thanks Alister :)
Old November 27th, 2007, 11:36 AM   #6
Sponsor: Schneider Optics
Paul.
Our B+W 82mm Slim UV Filters are the finest available made from a brass ring for easy screwing on and off as well as Water White Schott glass. Check it out here:
http://www.schneideroptics.com/ecomm...D=265&IID=3025
As always with B+W purchased from an authorized US dealer, you get a 10 year warranty on the filter. See Abel Cine Tech for US authorized B+W filters and a great price.
Ryan Avery
Regional Sales Representative
Schneider Optics
Ryan Avery is offline   Reply With Quote
Old November 27th, 2007, 01:58 PM   #7
As you'll see in my details - I'm in the UK - do you have UK distribution?
Old November 28th, 2007, 08:02 AM   #8
Hi Paul,
I have been using a Hoya low profile UV filter. It seems fine optically and I am not seeing any vignetting on my HSs18x5.5 lens.
Peter
Peter Newsom is offline   Reply With Quote
Old November 28th, 2007, 08:04 AM   #9
Thanks Peter :)
Old November 28th, 2007, 10:53 AM   #10
Paul,
South London Filter
London
Phone: ++44 20 7735 1900
Fax: ++44 20 7820 1718
Email: info@camerafilters.co.uk
Ryan Avery
Schneider Optics
