New Firmware and Memory Stick - Page 2 at DVinfo.net
Old March 9th, 2008, 11:29 PM   #16
Originally Posted by Greg Boston View Post
As I mentioned earlier, the prior firmware update has an updated Fresh file that should be installed. If you at least do that, then you should be okay to go the latest firmware. The AT and PKG file should completely overwrite the previous version when you do the update.
-gb-
Greg sorry but I'm a little bit confused at this point..
I never did the update with the MS-69A board (A-1356-823-A) I went from prior version to AT:1.53 Package: 1.62 without the board.
So I’m okay to go the latest version PKG 1.93/AT 1.60 from AT:1.53 Package: 1.62??
Don’t need to buy MS-69A board (A-1356-823-A)??
If so tell me where to buy MS-69A board (A-1356-823-A). please
William
http://osoriomedia.com
Sony Xdcam PXW-FS7M2 - Canon 7D & 70D - Adobe Premiere - Avid Media News Cutter
William Osorio is offline   Reply With Quote
Old March 15th, 2008, 11:39 PM   #17
Images: 1
That's pretty much what I did. No issues so far.
-gb-
Old January 26th, 2010, 01:51 PM   #18
Is it possible to check what FRESH version is installed?
Joachim Ljungquist is offline   Reply With Quote
Old January 27th, 2010, 07:26 AM   #19
Images: 1
Yes, turn on full user menu, go to Maintenance and find the page that lists ROM versions. That's where you'll find all the firmware versions.
-gb-
Old January 27th, 2010, 07:56 AM   #20
Greg:
Actually no... I found out that you have to go to the SERVICE MENU to see this.
(And I suppose you ment DIAGNOSTICS - but there you can only see versions of AT and PACKAGE, not FRESH).
Strangely enough - I have to use the DIP-switch inside the camera to get to the SERVICE MENU. I cant use the "ZEBRA"-way. That's a bit strange - I have succeded all the updates (now having FRESH 1.06, AT1.70 and PACKAGE 1.98).
Old January 27th, 2010, 08:05 AM   #21
Images: 1
That's correct. I was going by memory. It's the service menu ROM page that shows all the different firmware versions. My bad.
-gb-
Greg Boston is offline   Reply
