Go Back   The Digital Video Information Network > Sony XDCAM Camera Systems > Sony XDCAM HD CineAlta
Sony PDW700, F335, F355, F30, F70, and other XDCAM and CineAlta hardware.
Old June 24th, 2008, 06:09 AM   #1
350 Firewire Out
FAM mode simply stopped working. Tried different cables, firewire ports, computers...etc... Anyone run into this before? Solutions?
Dan Brazda is offline   Reply With Quote
Old June 24th, 2008, 07:39 AM   #2
Check two things:
1. On output option of Operation menu change ilink option to AV/C to see if ilink connector is still working.
2. Check version of FAM driver. Have you updated anything lately? Reinstall driver.
Other than that, it may be your ilink connection has bit the dust.
Bob Willis is offline   Reply With Quote
Old June 24th, 2008, 10:40 AM   #3
Thanks Bob. Unfortunately everything is pointing at a bad firewire port. When I hook up one of my other 350s to the same computer, using the same Firewire cable and all the same menu settings, one works perfectly and the other won't go into FAM. I just want to make sure there are no fool-proof tests to be absolutely sure the port is fried so I don't send it off to Sony for nothing. I'm running out of ideas.
Old June 24th, 2008, 12:58 PM   #4
Well, if it doesn't work in AV/C mode or FAM and the other components check out, I think you have a blown firewire port.
Old June 25th, 2008, 03:49 AM   #5
I Would ditch the FireWire cable you have been using before you blow another camera. Its normally badly constructed FireWire connectors that allow the power and data pins to short. Use good quality cables to minimise the risk of it happening again.
Alister Chapman, Film-Maker/Stormchaser http://www.xdcam-user.com My XDCAM site and blog. http://www.tvcameraman.info my home page.
Old June 26th, 2008, 10:31 AM   #6
Images: 1
Yours would not be the first F350 to suffer this fate. There was a demo camera going around this area a year or so ago that had a bad firewire port on it. I found out because I kept getting calls asking what they were doing wrong.
And as Alister suggests, good quality cables and connectors can reduce the likelihood of further damage in the future.
Sorry to hear that you're having such a run of bad luck, but I'm glad you didn't end up paying for the disc loader issue a while back.
-gb-
Greg Boston
Sony PDW-F350, Panasonic PV-DV953, FCP Studio
Old June 26th, 2008, 12:54 PM   #7
-gb-
Thanks Greg. Yeah, when it rains it pours. I didn't mention a recent accident with one of our lenses either but my rep at Fuji is incredible and sent us a loaner overnight. Long story short, all three of our 350s are in the field making pictures as we speak (albeit a bit battered and bruised).
  You are here: The Digital Video Information Network > Sony XDCAM Camera Systems > Sony XDCAM HD CineAlta
Google
