XDCAM Deck output at DVinfo.net
Old June 9th, 2009, 01:33 PM   #1
XDCAM Deck output
Does any of the XDCAM decks output realtime video from Premiere Pro and after effects similar to the DV tape decks?
Mitchell J. Skurnik
http://www.mjcsstudios.com/ - EX1, 4x hoodman 16GB, Libec Tripod, Sony LAV
Mitchell Skurnik is offline   Reply With Quote
Old June 10th, 2009, 02:27 AM   #2
Do you mean can they record live from Premiere or AE?
The U1 doesn't allow this - it's only a USB transfer device. I think the other (more expensive) decks allow recording in this way though.
Paul Gale is offline   Reply With Quote
Old June 10th, 2009, 06:55 AM   #3
Telecam Films
PDW-1500, PDW-V1, PDW-F70, PDW-F75 can output a DV stream through the firewire port. On the PDW-F70/F75, that is one way to get a downconverted output when playing a XDCAM HD disc. Note that the firewire port on these machines can operate in two different modes, FAM (File Access Mode) for files transfers and AV/C for DV25 streaming. You would want to make sure the i.Link mode on the deck is properly set to AV/C mode in order to capture the DV stream out of the deck.
Thierry.
Thierry Humeau, DoP
Télécam Films
www.telecamfilms.com
Thierry Humeau is offline   Reply
