Sony F350, Shutter on or off for Pal at DVinfo.net
Old August 31st, 2009, 01:51 AM   #1
Oh yes the shutter question again, but this time it's the Sony F350.
I'm a Pal user and my questions are..... should the shutter be on or off?
Should I have it set to second or degree?
How come I can only get 1/60 and not 1/50 for Pal.
I thought that 1/60 was for NTSC and Pal was 1/50.
Need some advice on this please.
Old August 31st, 2009, 05:29 AM   #2
If you're shooting interlaced then shutter off.
In progressive, On at half the frame rate (or better yet 180 degrees). If the camera doesn't have 1/50th then 1/60th will be OK - don't know why it wouldn't though.
Steve
Old August 31st, 2009, 06:11 AM   #3
The camera will only give you 1/60th as an option in interlace mode because when the shutter is off you are already at 1/50th. In progressive scan mode however the 1/50th option will be there.
Simon Wyndham is offline   Reply With Quote
Old August 31st, 2009, 07:06 AM   #4
The usual reason would be to allow you to shoot in 60hz countries without getting flicker.
Old August 31st, 2009, 01:45 PM   #5
Thanks guys,
Shutter off is 1/50 in interlaced mode. Got it.
Simon Denny is offline   Reply
