Anyone have the 24P upgrade on the 700 yet? at DVinfo.net
Old September 6th, 2009, 07:24 PM   #1
Just curious;
With the sony rebate I am thinking of getting it done relatively soon, and wondering if anyone has gotten it done?
I am assuming it has to go to sony direct to add it in?
not that it matters, does anyone know if infact it would rest all the camera settings when it is done?
Ryan
Ryan Hollings is offline   Reply With Quote
Old September 8th, 2009, 03:56 PM   #2
Yes, Not a problem
Ryan
If your 700 has a serial number below #12453 it needs a board for the upgrades. If not then all you need do do is purchase the upgrades, and Sony will send you a "Key" with instructions to do it yourself. Not hard, but if you have any issues please call the Sony Possie Help line at 800-883-6817 prompt 2/5/2. Basically you add the firmware to a memory card and follow the included instructions.
Dennis Dillon is offline   Reply With Quote
Old September 8th, 2009, 04:13 PM   #3
Sorry
Technical/Operation Issues----P.O.S.C. 1-800-883-6817 press 2,4,1 to access XDCAM operational support.
Old September 8th, 2009, 05:24 PM   #4
Originally Posted by Dennis Dillon View Post
Ryan
Thanks for the info Dennis,
I assume the "sony" price is the same, whether going the board route, or the key?
Ryan
Old September 15th, 2009, 08:14 PM   #5
To my knowledge, it is the same.
Old September 18th, 2009, 06:12 PM   #6
Sponsor: Abel CineTech
I have done many of these upgrades now and it does not reset the camera. However the firmware upgrade to version 1.51 that is required will change some values. Just save your settings to an 'ALL' file before hand to make sure you are in good shape.
The process is fairly simple, though annoying. We do it for many of our customers.
Andy Shipsides -Camera Technology Specialist
AbelCineTech, New York - Visit our Blog - http://blog.abelcine.com
Andy Shipsides is offline   Reply With Quote
Old September 22nd, 2009, 12:16 PM   #7
Images: 1
Originally Posted by Andy Shipsides View Post
IHowever the firmware upgrade to version 1.51 that is required will change some values. Just save your settings to an 'ALL' file before hand to make sure you are in good shape.
Andy, I won't swear this will happen with all situations, but beware that I had an issue where some of my shutter speed selections were missing. I did a 'reset all' which fixed the problem until I reloaded my saved ALL file. The problem was because that ALL file I was loading was saved under an earlier firmware version and was somehow corrupting things when I reloaded it. I ended up having to reset all, manually re-enter all my settings, then re-save the file under the new firmware revision.
Just a heads up...
-gb-
Greg Boston is offline   Reply
