XDCAM HD - downconverting to Sd-SDI while recording HD at DVinfo.net
Old November 10th, 2009, 07:55 AM   #1
Hi,
I'm looking for information, whether XDCAM HD cameras are capable of recording the 35Mb while outputting downconverted signal through SDI?
I know that EX is capable of doing so.
Adam Plywaczewski is offline   Reply With Quote
Old November 10th, 2009, 05:06 PM   #2
Telecam Films
Yes, the PDW-F355, PDW-700 and PDW-F800 can downconvert live to SDI. The PDW-F350 does not have a SDI output, only HD-SDI.
Thierry.
Thierry Humeau, DoP
Télécam Films
www.telecamfilms.com
Thierry Humeau is offline   Reply With Quote
Old November 11th, 2009, 04:33 AM   #3
The Sony EX3 is able to send SD SDI out of the camera I use this feature often recording SD to the NanoFlash while the camera records HD to SxS cards.
Lance Librandi is offline   Reply With Quote
Old November 12th, 2009, 04:59 AM   #4
Thanks for response.After playing a bit with our EX-1 SD-SDi output I found that it outputs all information from the viewfinder. While it's ok when using SDI for monitoring, it's not really desirable when using it for, say, live production.
Do the HDCAM HD cameras have it similiar? Or is there a way to disable SD-SDI output with informations overlayed on video, leaving "pure" video on output and information on-screen?
Old November 12th, 2009, 06:56 AM   #5
Vortex Media
Adam,
You can turn off the overlay displays on the EX1 and EX3 so the SDI output is clean.
1. Press the menu button
2. Go to VIDEO SET
3. Change the YPbPr/SDI Out Display menu to OFF
This changes both the component output and the SDI output.
Doug
Old November 12th, 2009, 08:59 AM   #6
thanks for the information, checked it, it works exactly the way described.
