-   Sony ENG / EFP Shoulder Mounts (https://www.dvinfo.net/forum/sony-eng-efp-shoulder-mounts/)
-   -   Ingest 50Mb/s 422 (https://www.dvinfo.net/forum/sony-eng-efp-shoulder-mounts/508362-ingest-50mb-s-422-a.html)
Eelco Romeijn June 8th, 2012 12:09 PM
Ingest 50Mb/s 422
Hi guys,
i'm recieving XDcam HD material to edit wich could be recorded in 422 mode. Does anybody know if this can be FAM transerred using my PDW 330?
Eelco
Robin Probyn June 8th, 2012 10:53 PM
Re: Ingest 50Mb/s 422
Not an expert.. but I believe FAM i Link will not work with 422.. only XE..
Eelco Romeijn June 9th, 2012 09:45 AM
Got the disks today and tested. Both camera and PDW F30 say: "not supported" so you are right Robin.
I was hoping that in FAM mode it just sees files and doesn't look at codecs...
The easiest way now is to rent a U1 or U2 drive.
Robin Probyn June 9th, 2012 11:55 PM
sorry to hear that.. I meant EX of course !! I only know as I was advised not to bother down loading the FAM software for SXS cards.. for 422..
Uli Mors June 11th, 2012 12:56 AM
Hi,
330/335/350/355 only read
- 35mbit 1440x1080 4:2:0 mxf
- 25mbit 1440x1080 4:2:0 mxf
- 18mbit 1440x1080 4:2:0 mxf
and
DV/DVCAM type SD mxf
For ingesting pdw700/800 50mbit 1920x1080 4:2:2 or IMX30/40/50 you definitely need either the cam (with SD Option for SD) or deck OR the PDW-U1 / U2 units.
If you regularly need access , IŽd advise to buy a U1 - they are getting cheaper (U2 is faster) and read and write EVERYTHING coming from the disk camcorders.
Uli
Eelco Romeijn June 17th, 2012 04:04 AM
Thanks Uli,
the rental U2 from Welkom - Europe Audio/Video Rent worked fine and was delivered the same day. (The material was recorded in an OB van)
Since i mostly edit my own material i'll stay with the cam as feeder and rent a U1/2 if needed.
