1080p? at DVinfo.net
Old August 22nd, 2006, 11:45 AM   #1
1080p?
I'm confused about the 1080p question. To my knowledge, the 330 does not qualify as a 1080p camera because it is 1440x1080 - correct? Sorry if this is a truly ignorant question!
Max Kaiser
Director, Hand Crank Films
http://www.handcrankfilms.com
Max Kaiser is offline   Reply With Quote
Old August 22nd, 2006, 11:56 AM   #2
The F330/F350 is as 1080P as any HDCAM or HDV camcorder as they all record only 1440x1080 pixels. On playback these are scaled to 1920x1080. The progressive images on the F330/F350 are created using interlace CCD's, some may argue that this means that the camera is not progressive because of this. However my experience with the F350 is that the progressive images it produces are true progressive frames at the same resolution as the interlace frames.
Old August 22nd, 2006, 01:54 PM   #3
Images: 1
Some HDV camera CCDS don't even record a true 1440, they use horizontal pixel shift. The F330/350 however, is a true 1440X1080 CCD.
Sony's high end HDC1500 records a 'true' 1920X1080 and true 60P. The body alone costs $90K.
-gb-
Old August 22nd, 2006, 06:45 PM   #4
Not even HDCAM is 1920x1080. The camera head on an F900 might be. But what gets laid down to tape is only 1440x1080.
Only HDCAM SR as a format is 1920x1080.
Simon Wyndham is offline   Reply With Quote
Old August 22nd, 2006, 10:48 PM   #5
Images: 1
If you're referring to my post, I should have clarified that the HDC1500 is not a camcorder. It's a camera head and going to HDCAM SR as you alluded to, it lays down a true 1920X1080. There's no upsampling or pixel shifting because the CCDs are native 1920X1080.
-gb-
Old August 23rd, 2006, 06:18 AM   #6
Sorry Greg, I should be more cohesive. I wasn't trying to correct you, but just make a general point that many people forget about the higher end HDCAM cameras compared to the lower end.
