-   Sony ENG / EFP Shoulder Mounts (https://www.dvinfo.net/forum/sony-eng-efp-shoulder-mounts/)
-   -   Laptop Edit Solution? (https://www.dvinfo.net/forum/sony-eng-efp-shoulder-mounts/89332-laptop-edit-solution.html)
Peter Newsom March 19th, 2007 01:56 PM
Along with getting an F350, I am looking for an editing solution as well. I currently don't have a laptop, so I'm starting with a clean slate. I have a bias towards Mac, but I could probably switch to PC, if I really had to. I really want to go laptop for the portability.
My primary objective is to get a efficient way to cut news stories and features on location, and hopefully documentaries and maybe music videos. I am not heavily effects driven at this point.
I would like the software to effectively use the advantages of the disk format, and to be fairly straight forward. I used to cut news the old way(machine to machine) and I have done a little work on a Media 100, but for the most part I will be staring from scratch in the non-linear editing business. I will need disk storage as well
What do you suggest in terms of computers, speed and ram, drives, and output formats?
Thanks, Peter
Vincent Rozenberg March 19th, 2007 02:19 PM
I'm a mac guy, so that's what my first choice is anyways, but with XDCAM and a macbook(pro) I think that's an winning combination overall.
The flexibility of the Sony software in combination with FCP is suburb. If you use a Matrox MXO in combination with this, you can even put out a live stream of HD SDI via the mini DVI out.
Kevin Shaw March 19th, 2007 03:14 PM
Originally Posted by Peter Newsom (Post 644354)
What do you suggest in terms of computers, speed and ram, and output formats?
If you're getting a laptop computer today, look for something with an Intel "Core 2 Duo" processor running at 2 GHz or faster, so either the Macbook Pro or any PC laptop with a T7200, T7400 or T7600 CPU. The Mac would be useful because it allows you to run both Windows and the Mac OS, but be sure to get a large boot drive if you plan to do both (and then partition it accordingly). I recently shopped several laptop manufacturers, including Apple, and ended up buying a Dell Latitude D820.
As far as editing software is concerned, Edius "Broadcast" version supports XDCAM HD and should handle that pretty well on a laptop such as described above. It also has some advantages over Final Cut Pro in terms of ability to mix multiple video formats on a single timeline without pre-rendering, and impressive real-time capabilities on today's fast laptops. Several Edius users are reportedly running it successfully on Macbook Pros for their editing work, and then switching over to the Mac OS for things like DVD authoring. That way you get the best of both worlds, and if I had things to do over again I might take a closer look at the MBPs.
Peter Newsom March 19th, 2007 03:41 PM
Thanks guys, that's great, just what I'm looking for. My idea is to transfer the edited work back onto the XDcam and play it out from the camera, or burn it to disk. So something that can work in the FAM mode both ways is key. I have heard some good things about Vegas as well, but it is PC based...
Is running the Mac in PC mode truly viable or are there disadvantages? I have only ever had Mac's so that's what I know best.
I won't actually buy anything for at least a couple of weeks, so I've got time to mull things over. My intention is to buy from a pro video supply place, so as to get a turn-key rig. That way(hopefully) I can avoid getting a poorly configured computer... Does that make sense, or would I save a lot by doing things on my own? (Penny wise, pounds foolish?)
Peter
Kevin Shaw March 19th, 2007 04:23 PM
I've heard a few reports of minor glitches running Windows software on the new Macs, but overall it sounds like that's working pretty well. Note that today's Macs are essentially the same as PCs except for the proprietary Mac bios chip, so it's not a big stretch to have them running Windows software well. Thank Steve Jobs for finally doing what Apple should have done 20 years ago...better late than never! :-)
Uli Mors March 20th, 2007 01:39 AM
If you dont have to edit big projects, a lot of effects etc. on your laptop, SONY VEGAS is a fast and COMPLETE solution to edit in the field as well, including proxy viewer + proxy editing etc.
AND: You can save your complete final master back to Disc in any Bitrate (18/25/35) - done.
Have a try with the demo!
ULi
Daniel Moreno March 20th, 2007 01:41 AM
PC+Vegas
Last year, as I learned the TV station I work with was buying XDCAM HD cameras, I struggled between staying in PC or finally changing to Mac. After checking the prices, specially in laptops, I ended buying a toshiba laptop, with a core duo processor and 2 GB of RAM that cost about $1200 (half what the Mac would have cost). I have been editing XDCAM HD for almost 6 months using Sony Vegas 7 and have no complaints at all!
Matthew Ernest Adams March 20th, 2007 08:46 PM
Edius
I've been breaking in an Edius Canopus over the past week or so and I like it. It's on a quad-dual processor (that's 8 processors if you're counting) and it's great. Import, export, but I haven't successfully imported partial clips in FAM mode.
As for a laptop and Edius, I'd recommend getting THE MOST powerful computer, with the most RAM and lots of memory. If you get an underpowered computer, you'll have to edit proxies and conform your timeline to HD at the end of the edit ... but once again, no partial clip transfer. If you use 5 seconds of a 60 minute interview, the entire interview will have to be ingested (changes promised soon).
In my opinion, FCP and XDCAM are fine on a full size Mac Pro ... a MacBook Pro will drive you nuts if you're used to smooth and non-stuttery editors. Just my opinion ... flame away>
Uli Mors March 20th, 2007 11:38 PM
If you get often in the situation of HEAVY partial FAM (5s out of 60min etc.) its better to use the SONY PDZ Software for FAM data transfer.
PDZ software can select a dedicated intervall and create a clip list (that we misuse as a batch import) and only transfer those parts of the clips you set.
In this case you´ll do some coarse viewing with the pdz and work with the full hd files afterwards.
BTW: if you set VEGAS to PREVIEW QUARTER (1/4 HD size, quality preview) you get a nice picture for preview @25 (PAL) or 30 fps - even on a 2.4GhZ...
ULi
Thierry Humeau March 21st, 2007 07:01 AM
Also, one should consider XPressPro 5.7 due next week. It will support all XDCAM XD and HD resolutions as well as proxy clips and will have the capability to write back. Not too shaby...
Thierry.
Bob Willis March 22nd, 2007 01:27 PM
If Xpress Pro 5.7 does indeed support all XDCAM SD and HD resolutions and proxies and Write back that will be great. But, I've heard the marketing and rumors before and have always been disapointed. Always something missing or locked out. I'll will wait and see what is released and how it works and hopefully, I will be pleasantly surprised.
Emanuel Altenburger March 22nd, 2007 02:00 PM
Avid Xpress 5.7
Just found that @ avid.com http://www.avid.com/content/10541/README_XpressPro.pdf
So writeback to XDCAM HD is definitely supported. But in this readme I couldn´t find any information about import of all resolutions of XDCAM HD. Thierry, are you sure about that? I know that you´re always top-informed about AVID questions. That´s why I ask you:-)
Peter Newsom March 22nd, 2007 02:40 PM
Does Avid still require ongoing licencing fees? I remember hearing stories about edit session being interupted until payment had been received.
Emanuel Altenburger March 22nd, 2007 03:09 PM
?!?! Really?! ! is that true? I can´t really believe that.
I´ve learned to work on an AVID in film school and worked on several AVIDs in post production houses and also on my own avid and have never had problems like that. That really sounds a bit strange ...
Peter Newsom March 22nd, 2007 03:15 PM
Well that was a long time ago, and since then most people used Media 100 or FCP in this area.
Peter
