FS5 stock lens focus wheel teeth
Hi
I have put my FS5 onto a rig plate and attached a focus wheel. I am having trouble identifying the teeth size / pitch on the lens in order to get the correct wheel made up. Anyone know what it is please? I'd consider an alternative gear belt method but I think they will cause problems where the belt in joined as the lens has no hard stops. Am I wrong in thinking that? Thanks... |
Re: FS5 stock lens focus wheel teeth
When close to the belt joint, just a single "jerky" short turn of the follow focus wheel will change the lens focus wheel range for you...
1 Attachment(s)
Follow focus systems are not really very useful on Sony lenses (speed sensitive so you will never hit the same mark twice) but having said that I do use them once in while for shoulder mounting) and got custom rings from followfocusgears.com $35
follow focus gears :: about Quote:
