Straight post on a Merlin Arm?
I'm currently using both a Glidecam and a Merlin and have the Merlin Arm and Vest. I'd like to use the GC on the Merlin arm but the post is curved. Has anyone found a way to retrofit a straight post that will work with the GC or found a source for one that will fit? My current option is to fabricate one myself.
www.weddingfilms.com/GLIDECAM_STEADICAM |
Hi Joel, tried this? : Steadicam | 801-7291 Pilot Arm Post Kit | 801-7291 | B&H Photo
Thanks Nick!
I just emailed them to find out if the diameter is right. Quote:
My guess is the post is not wide enough for the Glidecam. That post is for the Steadicam Pilot, which has a much smaller diameter "handle" than the GC.
Hi Peter,
Great article in EventDV, BTW... Quote:
1 Attachment(s)
http://www.dvinfo.net/conf/attachmen...1&d=1228190010 |
I have a GC as well as a pilot and I've considered making an adapter myself. All you really need is a bushing that will fit snuggly in the handle of the GC and has a hole in the center of the correct diameter for the Pilot post.
That would simplify it! Good thinking, Chris.
Thanks Peter,
Now if I could only spell BUSHING. :) |
Any update on this project fellas? I use a glidecam now and it's perfect for what I'm doing but the only problem is fatigue. If an adapter is created where I can use my friends Merlin vest and arm, that would solve alot of problems :).
I'd be more than happy to pay for an adapter! In the meantime, I'm going to go take the rubber grip from my spare tripod and see how that works out. |
1 Attachment(s)
Hi Randy,
I took the budget route. Works just fine. http://www.dvinfo.net/conf/attachmen...1&d=1234592159 |
How hard was it to take out the merlin post? It's not my vest so before I attempt this and potentially damage my friends arm, I'd appreciate any info on the risk of it. Sorry for barraging you with questions. Appreciate the help! Thanks! |
Hi Randy,
I'm so sorry its taken so long to get back to you on this. I had notifications turned off. Quote:
GLIDECAM_STEADICAM Quote:
When talking about different post types...
I have read tons of different topics related to Merlin and Pilot but there is one unclear question for me. I understand Merlin and Pilot have same arm only difference is that Merlin arm has curved post and Pilot has straight post. In order to use one or another with the same arm I should buy Post Kit. My question is that how hard or easy it is changing those posts. Do I need few hours of time and some tools for that change or it is just few clicks plug&play type of work? I have Merlin (handheld only) and now planning to upgrade to Pilot. I’d like to use my Merlin too with Pilot arm... so I have to buy Merlin Post Kit, right? Another question. Can anyone recommend some quick release plate system that would work with Merlin, Pilot and tripod without a need to change any plates? My camera is Canon XH-A1. |
