Hollywood Lite VS-1
This is made of aluminum and is for cams under 4 pounds.
Anyone tried it, used it, or heard anything about it? I think they're marketing it like a Steadycam JR, but better because it's not plastic. By the way, I recently saw some JR footage that was smooooth. I'm undecided about the JR because I've heard it's kind of rolly polly. |
Do you have a link to this product?
Here's the link. I have been thinking about a Flowpod. The Flowpod weighs about 5 pounds and the VS-1 is 2 pounds. Thing I like about the VS-1 over the Steadicam JR is that it's not plasic or fiberglass. I have heard of the JR breaking under the
weight of a DVX100. If you go to the page, click on the *yellow dot* for more information. http://www.hollywoodlite.com/VS1_Hand_Heldx.html |
Their products look pretty cool. I like the look of their Ultra-Lite stabilizer, which looks similar to the Flowpod, minus the monopod feature. It's only $15 cheaper than the Flowpod at B&H. I can't believe how expensive these things are.
I know what you're saying about the prices.
One thing that seems appealing about the VS-1 is that it seems to be designed more along the lines of what Charles Papert said was the ideal for these handheld stabilizers--light as possible, wider at the bottom rather than narrow, shorter rather than long. I'm sure Charles will correct me if I'm wrong. |
True enough Dave.
I've played a little bit with the Hollywood Lite products. The VS-1 is simple and sturdy and should work fine for basic stabilizing needs. I think it's somewhat limited in its ability to tilt though. The Ultralite seems decent, although I'm not sure about the gimbal. Haven't flown it. I don't know what to tell you guys about the prices. One has to remember that these are not mass-produced items, essentially made by hand (well, CNC machined one at a time, at any rate) and with sales projections measured in hundreds of units. Before the introduction of the JR, the next cheapest camera stabilizer of this type cost something like $8000--and that was radically cheap at the time! Speaking of which, the JR itself is not inherently "rolly polly". It is a precision instrument with low friction, which makes it more susceptible to being overly controlled. A system with a stickier gimbal may resist its owner's efforts, but result in less smooth photography overall. |
Do you think it would give better flying shots than the Flowpod?
From the picture, it looks like the handle is a bit off to the side, similar to the Glidecam 2000. I would think this "being off from the center" could lead to wrist strain. The Flowpod can be operated with the handle right underneath the center of the cam. |
