A1 mounted on Merlin. Vibrations while walking
Anyone else having problems with an A1 on the Merlin and experiencing jittery footage due to vibrations while walking?
No matter what I've tried, there seems to be a slight movement of the cam, on the Merlin, to cause jittery footage while walking. Any advice would be greatly appreciated. My setup is a stock A1, BP-945 Battery. The Screw is touching between the focus and zoom ring. Thanks |
Guess I just have a bad Merlin?
OIS disabled?
are you saying the the shock from your footsteps is showing up in the footage?
If so It may be the way you're walking. I'm around the 100k and have a large stride which translates into very heavy footsteps and jittery footage (Godzilla's POV) - I'm still working at it, smaller footsteps, the groucho Marx walk - I think (I hope) it;s just a matter of practice, practice, practice. |
Steve Winter's suggestions sounds like the best guess to me.
yes OIS is disbled.
I'll try different walking techniques, but I've seen footage with people running while getting really good footage with these, so it makes me wonder how I would be walking too hard. |
No, it's not "bad" Merlin,
do you have "gezornenplatz" screw in place? with larger cameras it helps before you'll learn how to walk :) |
This is difficult to figure out.
If you hold the plate still, can you move the camera ie is there any play? I don't see how you can introduce vibrations whilst walking. Movement but not vibration. |
maybe some footage would help - then we can see exactly what you're talking about
Keep the arm and shoulder holding the Merlin relaxed.
Instead of taking steps, walk in a continuous, unbroken relaxed movement cycle. Without the Merlin, practice walking in smooth slow motion, controlling the muscles in a very relaxed way. It will be difficult at first, but improvement here will show in the Merlin later. |
Buba- I do have the g-platz screw in place. It's touching between the zoom ring and the aperture ring.
Richard- there is no play while holding the plate. The plate flexes a tiny bit, but it's mounted on the cam securely. Paul- I'll try to post some footage. Jack- Thanks. I'll try practicing walking this way. |
You should be able to walk normally and have no problems. Vibrations are normally because something is loose.
Try asking on the steadicam forums in the newbies section or better yet contact Tiffen. their customer service is second to none both here in the UK and in the US. I had to get my pilot adjusted and was able to take it into my UK branch and they did it there and then. |
One other thought.
I've seen the grub screws work loose on a Merlin that was rented out. The screws I am referring to are the ones that hold the tubing of the curved arms to the mouldings that connect the tubes to the hinge. Are any of these loose perhaps? |
Grub screws were nice and tight. There seems to be a tiny bit of play in the joint where the arc adjustment knob is. It seems to be in the silver round channel that keeps each arc piece in position. In the locked position, if you grab the ends and try to move them together as if to touch the ends together, and then away from each other, I notice a bit of movement, and as in a bit, I mean just a little. I hope I explained that, so it made sense.
