homebuilt monopod stabilizer question
I have a very sturdy Manfrotto monopod that I would like to convert for use as a Glidecam-type stabilizer by adding weights at the bottom.
The Manfrotto monopod came with a round screw-mount base at the top. It isn't very large, probably about 2 inches in diameter. My question is: is it safe to mount my PD-150 directly to this round base when using as it as a homebuilt stabilizer? or do I need a larger 'platform' between the round screw-mount on the monopod and the PD-150? |
You might want to attach something like a 357PL sliding plate adapter. that will allow you to quick connect to your homebuilt unit or a tripod and you can slide the camera along the length of the plate to the point of balance and then lock it. I use one on my monopod.
http://www.manfrotto.com/products/me...ontatore=primo |
I just wanted to make sure that little 2-inch diameter pad was going to provide enough support for the PD-150 while in motion.
The whole point of using a stabilizer is that the camera is moving while filming. <<<-- Alex Knappenberger typed : Yeah, it was made for having a camera mounted to it, so why wouldn't it be good enough? -->>> |
Thanks Bryan that looks awesome!
Where do you find something like that? B&H doesn't appear to carry them... <<<-- Bryan Beasleigh typed : You might want to attach something like a 357PL sliding plate adapter. that will allow you to quick connect to your homebuilt unit or a tripod... |
