Is my camera too light?? at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Additional Camera Support Topics
Old August 19th, 2007, 09:57 AM   #1
I would like to purchase the Libec H38 Professional Fluid Head for use with my Canono XH A1-- which I don't own yet. [g]
How well do you think this plan would work until I get the A1:
1. Buy the H38 head only for use with my Optura XI.
2. Put the head on my current photo tripod (Slik 212)
3. When I get the A1, purchase the base for the H38 as well.
I see it the specs for the H38 it states that it supports up to 17.6 lb. Would a much lighter camera be difficult to use on such a head? I expect there's probably a "sweet spot" with respect to how smoothly the mechanisms work with regard to the weight of the camera used?
Tim Ribich is offline   Reply With Quote
Old August 19th, 2007, 11:10 AM   #2
Images: 32
I would wait until you get the XH A1. The Optura Xi is 1.6 lbs. You'll probably encounter additional issues from such a mis-match.
"Ultimately, the most extraordinary thing, in a frame, is a human being." - Martin Scorsese
Michael Wisniewski is offline   Reply With Quote
Old August 19th, 2007, 11:48 AM   #3
The Libec uses a 75mm ball, which is incompatable with your current tripod.
Old August 19th, 2007, 08:06 PM   #4
Thanks for the input.
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Additional Camera Support Topics
